compression ratio
compression ratio
I WAS JUST WONDERING HOW PEOPLE LIKE SMASTERSON AND OTHERS ARE GETTING AWAY WITH COMPRESSION LIKE 11:1 WHEN I WOULD BE LUCKY TO BEAT DETONATION WITH 9:1 ? SMASTERSON, GOT ANY SUGGESTIONS WITH THE 383 I WILL BE BUILDING? HERES WHAT SHE WILL HAVE BELOW!!
350 .030 OVER
BORED AND HONED W TOURQE PLATES
SCAT 9000 SERIES 383 CRANK
SCAT 4340 I BEAM RODS
SPEEDPRO LIGHWEIGHT 10.7:1 FLAT TOPS W 64CC
SPEED PRO PLASMA MOLY DUCTILE RINGS
CLEVITE P SERIES BEARINGS
CLOYES TRUE ROLLER TIMING SET
AFR 190CC STREET HEADS L98 PLUG 68 CC COMBUSTION CHAM
COMP CAM 12-433-8 HYD ROLLER CAM
CRANE ROLLER LIFTERS
TRICKFLOW PUSHRODS
COMP CAM PRO MAGNUM ROCKERS
MELLING Z28 HO OILPUMP
ARP OIL PUMP SHAFT
STEALH RAM INTAKE W 30LB SVO INJECTORS
CUSTOM BURNT PROM FROM NEXT GEN
WELL THERE IT IS, ACCORDING TO AFR I SHOULD HAVE 500HP? I HOPE BUT TELL ME HOW TO AVOID DETINATION!!!
THANKS BADGTA!!
350 .030 OVER
TRICKFLOW PUSHRODS
ARP OIL PUMP SHAFT
THANKS BADGTA!!
Damon
09-26-2015 04:29 PM
83 Crossfire TA
09-08-2015 12:06 PM
