Code 12 and 32 fixes
Car: 89 IROCZ28
Engine: 350TPI
Axle/Gears: 2.77 Gears
I was on my way to LA a couple days ago and my car threw 3 codes at me. Two 12's and a 32. The only other time I've gotten a code was another 32 again on the way to LA but after restarting the car I never got it again at least until 2 days ago. Anyway how do I at least go about fixing code 12? I'm not too worried about 32 at this point. Any help would be appreciated.
Ryan
Ryan
Location: Somewhere in between Lynn, MA (home) and Lakeland, FL (school)
You don't go about fixing code 12. 12 essentially means that your code diagnosing system is working properly. It says "I'm OK!". 32 is your only problem.
1 Post
Car: 84 Z-28 Camaro
Engine: 383
Axle/Gears: richmond 3.73, eaton posi
not sure what a code 32 is but code 12 is "no distributar refrence pulse" bacically it means your car ain't running.
For code 32 info, check out The Low-down on Code 32
BumpaD82
02-26-2016 02:57 PM
MikkoV
09-09-2015 04:25 PM
