Mr. Gasket HEI recurve kit problems
Car: 84' Monte
Transmission: 700-r4
Axle/Gears: ferd 9" posi 3.50 gears
Ok I have a vacume advance HEI distributor with HO coil stock module and Mr. Gasket recurve kit. The problem is i can't get more than 10 degrees of machancal advance out of it. I set the base timing to 10 deg and i will only get 20 deg totall. It all comes in before 2500 rpms. I have tried all of the springs, the light ones actually give me less timing because they are putting timing in at idle also the timing is eratic at idle with the light springs. I have tried flipping the cam plate over , the center plate the weights ride on. I also checked to see if it was being restricted by the slots that the pins go through and i still have a 1/4 inch left when i pull the weights out al the way. I'm all out of idea's. I'm hoping this is just a junk recurve kit . Has anyone had this problem before.
Car: '94 Corvette
Did you make sure the wieghts are right side up ? I notice you fliped the cam deal.
I had one set were the shiney side of the wieghts went down, and the cam was shiney side up.
I'm out of ideas, aside from getting a different set. I think Accel makes a set.
Ron
Ron
Car: 84' Monte
yeah i'm sure the weights are on correctly because there are little plastic pads that they ride on so they can really only go one way. I'm thinkin its fubar so i'll prolly just get a different recurve kit and see what happens.
Hellraiser
Car: 84' Monte
I disable the vacume advance when I check the machanical advance. But I have it set to add 10 deg when it is engaged.
Stop using the Mr. Gasket recurve kit. It's junk. I've tried them all and it's gotta be the worst. Go buy the Crane kit.
For street performance what you really want is stock weights and centerplate combined with slightly lighter springs. This is what the Crane kit is, plus a fully adjustable vacuum advance can. There's a tech article on this website about recurving the HEI for performance applications.
Car: 84' Monte
Thanks for your input damon, glad to hear some one else has had problems. I'm going to dig up my old weights and cam plate and use the springs with the Mr.G kit
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
"The Mr Gasket HEI recurve kit is junk."
My conclusion from about a decade ago. Sounds like nothing has changed.
ambainb
04-25-2016 09:21 PM
NinjaNife
08-23-2015 11:49 AM
