how can you get rid of that ugly heater box thing over the valve cover
after taking out the air conditioning and pump i was wondering how you takeout or relocate that ugly box thing over the valve cover, and or can i see some pictures of it (pictures are worth a 1000 words) thanks
go to your friendly neighborhood sdalvage yard and look for an a/c delete heater box. trust me, you'll know it when ya see it. the front is pretty much flat with no opening for the big a/c lines to pass through. usually you can pick up the box and the a/c delete contorls ouyt of the dash for about $30.
later
tim
later
tim
im talking about the thing over the valve cover that has 2 hoses tot the firewall and one to the rear of the intake, and also has a vacume line, is that what you are talking aobut
Car: 91 Red Sled
Yeah, that was me. I have a tech article on my webpage.
It's easy and now the heat comes on right away. That vacuum line going to the switch only lets coolant rush into the heater core if you have heater,vent, or defrost selected on the climate controls. Personally I leave my climate controls in the off position when turning on my car, then I turn the heat on when the car has warmed up.
Car: 1985 Camaro, 1986 Trans Am
Engine: 5.0L carbed and 5.0L TPI
Transmission: TH700R4
Axle/Gears: 3.23 and 3.27 posi
JPrevost, could you post a URL to that tech article?
Car: 91 Red Sled
http://www.0x58.org/jprevost/cars/heater.htm
You guys are lazy. It's only 3 clicks to get to that page if you go to my website (in my profile).
My friend just took some pictures a few days ago of the engine bay and I should have those pictures soon.
glad someone did this because i already got rid of the air pump box of crap thing right beside it...with that heater hose outta the way and the AC gone putting on headers should be a piece of cake on that side...engine is starting to look primitive to with the open element, no AC, and with the heads itll look nice...dont know how many people have asked if i carbed that car after seeing the open element...probably been asked that at least 20 times already
NBrehm
08-25-2015 11:49 PM
