timing jumps 6-8 degrees during base timing setting
Car: 92 B4C/91 Z28
Engine: 5.0/5.7
Transmission: 5 SPD/700R4
Axle/Gears: 3.42/3.23
I understand how to set the base timing,, unhook tan wire,,, have 95 454 im setting and while i was setting the timing to 4 degrees,the engine wanted to stumble a lil and i reved the motor some and noticed the timing mark on balancer jump from 4 degrees btdc to 10 -13 degrees btdc,, i know motor should be a idle during timing, but the engine doesnt rev more than 300-400 rps before it jumps 6-8 degrees.. is this normal for the timing to jump that much during base timing setting, or is there other issues going on?? Distributor is from a working engine that had no problems running,,
Car: 1987 Trans Am
Re: timing jumps 6-8 degrees during base timing setting
Silly question but someone will ask so i'll be the guy , did you have the dizzy tightened all they way down when you reved the throttle?
Car: 92 B4C/91 Z28
Engine: 5.0/5.7
Car: check
Engine: check
Transmission: check
Called limp mode advance. Usually comes in at a higher RPM, such as 1400 - 1600 RPM. Maybe that year BBC GM has it coming in sooner.
RBob.
RBob.
Abubaca
12-16-2020 01:02 PM
BG1959
07-20-2016 02:22 PM
