TBI extra injector drivers?
Hey Guys,
I haven't been on here in a long while.
I wanted to ask what the current best way is to drive 2 extra TBI injectors.
Does someone make an injector driver board, or is there a SSR that's fast enough?
I want to do 2xTBI's on a dual quad intake for my next project.
Thanks,
Ben.
Thanks,
Ben.
1 Post
Car: 1990 Formula Firebird
Engine: 305 TBI (LO3)
Transmission: WC T-5 out of an 88 T/A
Axle/Gears: 10 bolt, 3.42 & Torsen Posi
Re: TBI extra injector drivers?
You have my attention sir. The thought of a multiple TBI setup with the 2barrel TBs (not the single barrel crossfire TBs) has crossed my mind a few times. I would love to see someone pull this off, maybe if its not tooo difficult I'll attempt to follow in your footsteps when I get around to doing my 350 swap
It's been discussed here many times in the 10+ years I've been reading this board and playing with TBI/CFI, but I don't recall anyone actually doing it..
A 2" BBC TBI will supply enough air/fuel for most small blocks, 2x2 on a 2x4 intake just looks cooler... Tripower even cooler again
1 Post
Tri-power would be bada$$, but thats probably why its never been done, a single TB would be way easier.
1 Post
Car: 1991 firebird
Engine: TBI 305 (built)
Axle/Gears: 4.10
Would b awesome to pop the hood on a N/A 10-11 sec car and show off a dual TBI setup lol ... people b scratching their heads for a week .... saying was that car really tbi
Car: 1983 G20 Chevy
Transmission: 4L60
I have considered fabricating an upper plenum for dual TBI numerous times for one of the leftover L31 Vortec lower manifolds I have hanging around. The manifold itself is very similar to crossfire and has massive runners compared to a crossfire. A small cap HEI EST distributor will also clear at the rear of the manifold. After all the vortec injector junk was removed out of the plenum and the manifold was ported out I feel it could easily flow 260+ CFM.
Axle/Gears: 10 Bolt 2.73 Open
Wonder how these guys make it work?
http://howellefi.com/tbi-kit-twin-tb...ig-blocks.html
Car: 1983 G20 Chevy
Transmission: 4L60
My personal favorite TBI setup! Its a big block that came from the factory with dual 2" bore TBI units and a blower and has since been upgraded to an 8-71.
Car: 75 Beast
Engine: 383 +EBL Flash
Axle/Gears: 4.11 with 33"
Fast
I looked at Vortec intake couple years ago for a possible 2x2 TBI setup. The bottom portion of Vortec intake does not offer too much plenum volume - it is not a bath tub shape like CF intake. Vortec intake plenum volume is in the upper portion of intake. I would have to start with 1-1/2" or thicker solid block of 6061 to machine an upside down tub to have decent intake plenum. Alternatively, a 2 piece solution consisting of a ring frame and tub top cover can be machined to achieve decent intake plenum. Unfortunately, I no longer have access to XYZ measurement and inspection system and CNC center. CAD design is 1/3 of the effort while measuring existing bottom portion of the intake and fabrication are the other 2/3... It does sound like a fun project!
//RF
Car: 1983 G20 Chevy
Transmission: 4L60
Fast
//RF
//RF
ambainb
04-25-2016 09:21 PM
