Building 92 Camaro RS 305
Car: 1992 Camaro RS
Transmission: A4
I have a 92 Camaro RS with the 305. It's all stock. I believe it has around 170hp and I'm interested in pushing it to 300hp to a max of 400hp. What parts would I need to make this possible starting with the engine to the transmission and etc. to stay reliable? Without doing a 350 swap, what are my possibilities? I'm just curious to see what would need to be done because I don't want to pull the entire motor out. Also, I found Hooker Super Comp. Headers full length for $500 brand new for my car, is it worth it? If I can't get 300hp or more out of the motor without pulling it, what heads and other parts could make it possible to accomplish 250hp or more? It only has a Flow Master Exhaust system. Any help would be much appreciated!
Car: 92 RS 25th Anniversary
Engine: 305 TBI -> 305 TPI
Transmission: T5/T56
Axle/Gears: 3.08 - 3.73+ soon
Re: Building 92 Camaro RS 305
300 to 400 hp out of a TBI 305?
I wouldn't even try. It would be cheaper to just build another engine.
You could throw a 150 shot of nitrous at it. But you still won't reach those numbers.
Car: 1992 Camaro RS
Transmission: A4
I plan on trying to exceed 225whp, but is it possible to do so without pulling the bottom end, installing better cylinder heads plus headers and/or intake manifold?
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
A friend put Vortec heads, a Stage 4 single plane intake from Summit, and Lunati Voodoo cam on his 305 and dynoed more than 240HP to the rear wheels.
Car: 1992 Camaro RS
Transmission: A4
Damn! Did it have exhaust and headers on the car as well? I was told if the car already has o2 sensors/cat that i should keep them so the car will run the way it should. Therefore, get shorty headers instead of full length. Would that be correct?
Car: 1992 Camaro RS
Transmission: A4
Also, say I wanted to do a 350 swap such as a LT motor into the 92 RS that previously had a 305 V8. Would the transmission fit and handle the horsepower? If so, would the transmission be capable of handling up to 450hp? I plan on building a 305, but if it's literally that insane or difficult, I may just save up for a 350 and build it to create 400hp. Possible a 383 stroker.
84z96L31vortec
08-20-2017 12:16 AM
db057
08-11-2015 10:11 PM
