chevy van 4.3 V6 1990 not enter to closed loop
Hello,
I have a chevy van G20 4.3L V6 1990, the problem is that the ECM did not enter into a closed loop, changed oxygen sensor to sensor is heated (3 wires) and no change, temperature sensor was replaced two years ago and was the oxygen sensor wire 1's still not going imprisoned closed, no have catalytic converter, could be the problem? ECM 1227747, what I get from WINALDL:
When I connect a USB cable to ALDL the rpm up to 1000 rpm,
IAC: 19
MAP: 27.7 KPH
TPS: 2.2%
o2: 0.080
Knock: 198
rich / lean counter: 114
Many thanks.
yossi
IAC: 19
MAP: 27.7 KPH
TPS: 2.2%
o2: 0.080
Knock: 198
Many thanks.
yossi
Re: chevy van 4.3 V6 1990 not enter to closed loop
Well, I'd start by check fuel pressure, ecm grounds, vacuum leaks,make sure the ignition timing advances, ect. I'd do that before replacing the ecm.
with a 10k resister across a to be the idle speed will increase and knock retard will not occur. Close loop should be obtained at about 104F (185 ohms) that reading is off the ect. The o2 also needs to be actively moving and 500-600f. Is this a bcc from a export ?
bcc is the broadcast code of the eprom the three to four letters on top of the chip. so this data is just a snapshot of idle ? Is your o2 moving ? Most gm single wire or heated will be stuck at 450mv when they crap out or will be real lazy in swing.
yes the, o2 moving, this snapshot of idle but on 1000 rpm because the 10K resister ?
This the cabel i have
http://www.ebay.com/itm/GM-OBD1-Scan...ffa868&vxp=mtr
I now will check the BCC
on the ecm have 2 chip, on the little chip write 8925 and on the big chip write 8609, Anl j . i was remove the 10k resister and:
Rpm: 800
Temp: 186 f
Iac: 16
Map: 29.2 Kpa
Tps: 0.47V - 1.7%
o2: 0.897
Knock: 21
rich/lean counter: 49
And the flag data that on:
Idle/cool flag
ESC 43B Ready for second pwr enrich
Rich flag
Asynchronous fuel flag
and DRP occured sometimes
Rpm: 800
Temp: 186 f
Iac: 16
Map: 29.2 Kpa
Tps: 0.47V - 1.7%
o2: 0.897
Knock: 21
Idle/cool flag
Rich flag
The anjl should be a good file gm 16125098 I dont have a copy of it. The engine's running rich have you checked for leaking injectors? You can use a timing light and shine at the injectors and see dripping. the map look ok between 30-50 kpa 1-2v at idle. Tps looks good as well. Dose it go into cl off idle after a few minutes ?
My ecm number 1227747, i was replace the all tbi before 40,000 mile to new
Can you tell me what it is?
ESC 43B Ready for second pwr enrich (Disappeared from 1000 rpm and up)
It's okay it's on?
It's not even idle went to closed loop
It's okay it's on?
Another thing by canceling the 10k resister does not appear to me error codes
(I know this because resistor connection socket B is a diagnosis)
