305tbi to this 350?
Car: 92 Camaro RS
Engine: 305 TBI
Axle/Gears: 10 Bolt 3.42 Posi
305tbi to this 350?
Im on a budget and may need a new engine soon. The engine I found I am not sure If I could use my TBI setup on. I know I would need 350 injectors, the right ECM/Prom. but would everything else bolt right up including wiring harness?...here is the engine..
http://www.summitracing.com/search/P...e&autoview=SKU
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Engine: gone
Transmission: gone
Axle/Gears: gone
Re: 305tbi to this 350?
you can use it. the intake is not a direct bolt on you would have to oblong the holes as those heads have different angle center intake bolts. everything else should transfer over from your 305 though. as far as i know.
Car: 1991 Formula
Engine: 350TBI
You would just need 55# or bigger injectors, I use 90#. 350 knock sensor(always buy new) AND a 350 esc module which you take take from a hunt yard
Car: 92 Camaro RS
Engine: 305 TBI
ok so here is the list..
55# or 90# injectors
ECM/Prom (350)
350 Knock Sensor
Ported Intake Manifod
350 ESC
1.)Is there a direct bolt-on TBI manifold for this application?
2.)I have a 92 (20 years old) I have till 25 years in the state of Virginia (northern) to pass smog. Would I have any issues with smog with a 350TBI?
JEGS has this one it has alot more horsepower but it says its Carb. It seems like a better deal tho.
http://www.jegs.com/i/Chevrolet+Perf...67353/10002/-1
ECM/Prom (350)
350 Knock Sensor
350 ESC
Car: '88 Black GTA, T-tops, digital dash
Engine: 5.7 TPI w/custom chip
Axle/Gears: 9 bolt 327 posi
Same issue with the four manifold center bolts.
Car: 92 Camaro RS
Engine: 305 TBI
So how many manifold bolts does mine have? If I take my manifold to a machine shop what do I tell the guy to have him make it work?
Engine: gone
Transmission: gone
Axle/Gears: gone
you have the same amount of holes. the difference is the angle of the center intake bolts.
Car: 92 Camaro RS
Engine: 305 TBI
Before I actually do this swap will my emissions still pass as a 305tbi with a 350tbi in there?? Im sure the emissions guy couldnt tell by looking at it but I need to kno if it will pass off as a 305 when it comes to emissions?
Engine: gone
Transmission: gone
Axle/Gears: gone
it will be fine emissions wise.
you need to oblong the holes on the intake to make it work. they sell a washer kit that helps the bolts tighten down properly.
1 Post
Car: 91 Trans am
Engine: built 360 TBI
Transmission: built 700r4
Axle/Gears: 10bolt/3.23
The LO5 GM#12513151 should be a direct replacemet for the LO3 and has a roller cam.
Car: 92 Camaro RS
Engine: 305 TBI
I found one place that sells this engine at $2500. I was thinking more like 2k for a stocker. If anyone knows a cheaper place let me know please. http://autoplicity.com/products/1283...odwrench_.aspx
I found this from some company called pace performance... they say GM discontinued this engine????
http://paceperformance.com/i-5133946...-brougham.html
1 Post
Car: 91 Trans am
Nice, but do you kno who sells this? I cant even find one on ebay. I did find 350 tbi truck engines but I dont think they are the same.
It is a pity if they do not sell them anymore.
Car: 92 Camaro RS
Engine: 305 TBI
It was confirmed I called and that particular L05 is indeed discontinued which does not make sense because they came in 93 vehicals that are not even considered "classics" yet in most states. So I guess Im leaning toward this one.
It seems to have pretty good power but im not sure about emissions with the pistons and upgrades it has. Would I need this -
Angle Kit
http://www.summitracing.com/parts/PFS-52110/
-OR- this Straight Kit for the manifold.
http://www.summitracing.com/parts/PFS-52112/
Angle Kit
1 Post
Car: 91 Trans am
** Chevrolet Performance 10067353 - GM Goodwrench 350ci/260HP Engine & Packages
This universal 350ci engine uses a brand new block and can be used as a replacement for most GM vehicles from 1973-85. It produces 260 HP and 350 ft/lbs torque with a 4-bbl carb and headers. It can be used as a replacement or as a retrofit into almost any vehicle. This brand new 350 crate engine comes with a GM warranty and is covered for 3 years or 100,000 miles in applicable GM vehicles only. JEGS has the GM Goodwrench, Chevy 350 engine for sale at a great price!
Specifications
4-bolt main with 2-piece rear main seal
Cast iron crankshaft
LT1/LT4 powdered metal connecting rods
Cast pistons (dished)
Hydraulic flat tappet cam (.383''/.401'' and 112° lobe separation)
Cast iron cylinder heads with 76cc chambers
8.5:1 compression ratio
Block is compatible with left or right side oil dipstick (Requires Plug for Unused Side - Plugs are Included)
4-quart oil pan
Timing tabs for a 6-3/4'' or an 8'' balancer
Recommended spark plug: Accel #111-574 or any spark plug with 14mm .460'' reach, 5/8'' hex, tapered seat, projected tip **
By reading the description, it would make sense to drop this engine, on the heads of the persons that decided to sell it and that discontinnued the LO5 GM#12513151
Specifications
4-quart oil pan
![crazy](https://www.thirdgen.org/forums/images/smilies/crazy.gif)
Car: 92 Camaro RS
Engine: 305 TBI
I know I just want a good replacement, insted I will probly be forced to downgrade in technology, they still had the L05 on the SD site but they were the truck versions, whats the differance on the car model?
1 Post
Car: 91 Trans am
Truck LO5's have mainly flat tapped cams, for exemple GM 12568758.
Otherwise can look at the L31, but will require new intake manifold and some plumbing for the EGR.
Car: 92 Camaro RS
Engine: 305 TBI
I did find some complete salvaged L05 caprice engines. There is a risk with anything used so I will weigh my options. Thanks guys.
