383 parts list and build thread
1 Post
Car: '91 Camaro RS
Engine: Carb'd 383
Transmission: Built T5
Axle/Gears: 3.73 Posi
Just got my block back from the machine shop, it was a '95 350 TBI from a truck, I got the cylinders bored .030 over, got the holes tapped for the spiders so it's now roller ready, and got it cleaned/new bearings/freeze plugs and all that basic stuff
Parts list:
Scat 9000 series 383 rotating assembly (cast steel crank, forged rods and pistons, plasma ductile rings, 9.8:1 cr with 64cc heads)
OEM roller cam assembly (kit includes spider, dogbones, lifters, and bolts)
Not sure on pushrods, I need to measure for the size I need when I get the cam
Comp roller cam (.560/.560 lift w/1.5 rockers, 230/230 dur. @.050, 110 lsa)
Patriot performance vortec style heads (185cc 2.02 valve intake, 60cc (?) 1.60 valve exhaust, 64cc chambers)
Edelbrock RPM air-gap vortec style intake manifold
Holley 770cfm 4-bbl carb (elec. choke, vac. Secondary)
Hooker headers with pipes running back and turn out right in front of the rear wheels
3.42 posi rear
Rebuilt 700r4 with a reverse manual valve body and b&m ratchet shifter
I think that's all I have planned for now, engine/drivetrain wise anyways
Id appreciate anyone's input on any of these parts or combination of parts and this will turn into a build thread in about a month, this is going into a 91 RS with a 305 and it will be taken to the drag strip multiple times per year, but not in any really big events
Parts list:
3.42 posi rear
1 Post
Car: 91 Trans am
Engine: built 360 TBI
Transmission: built 700r4
Axle/Gears: 10bolt/3.23
Re: 383 parts list and build thread
383 TBI, cool
Heated single plain intake manifold over the air gap and GM 54mm TBI TB.
That's a big cam, you are courageous.
1 Post
Car: '91 Camaro RS
Engine: Carb'd 383
Actually, it's going to be converted over to a carb, it is TBI right now tho, and what advantage would I get by measuring piston to deck? Just wondering, and I had both decks cut parallel to the mains
1 Post
Car: '91 Camaro RS
Engine: Carb'd 383
Oh and with the cam, the heads will take .575 lift, so it's almost the biggest cam I can use, I'm hoping it'll make a lot of torque
Car: 75 Beast
Engine: 383 +EBL Flash
Axle/Gears: 4.11 with 33"
Get rid of that 110 LSA cam. Comp Cam can grind the same profile on 112 to 114 LSA and it will work with OK with EFI - you'll have at least 14 to 16 in-Hg at idle. Naturally, custom tune, BBC TB, 80 lb/hr injectors and higher fuel pressure will be required. I built a similarly configured engine 2years ago - and it is please to drive in 4000+ lb Monte.
Surprised more than a few rice rockets and pony drivers.
Use push rod checker to determine length.
//RF
//RF
1 Post
Car: '91 Camaro RS
Engine: Carb'd 383
//RF
//RF
evilstuie
02-28-2016 03:33 PM
