max. fuel pressure for a tbi ...
i've always been under the impression that 30 psi is max safe fuel pressure fore a tbi . after doing some recent searches i've found some people pushing these limits . looking for imput from people running max fuel pessure in a tbi
Re: max. fuel pressure for a tbi ...
i understand feed it what it needs . my question tho is what is the max. safe psi the injecters can be run at ? i other words whats the upper limit for fuel pressure before you have to buy new injecters ?
High psi doesn't kill them, i don't understand what your going after? When you say new, do you mean higher flowing too? Most that run higher psi are using 305 injectors on a larger engine, like a 350, 383, or a 400.
92camaroJoe
08-13-2015 06:07 AM
