BURNER2
Car: 91 Firebird
Axle/Gears: 3.08
BURNER2
Stupid question, but I want to make sure i'm reading this correctly, but the moates burner2 does NOT program the M27C256 EEPROM, only can read??
Car: 91 Firebird
Axle/Gears: 3.08
Re: BURNER2
I read that sticky on the tuning wrong... I thought in the traxions post it said for the 90-92 TBI and after rereading it says TPI, of course i bought 5 of the 27C256 EEPROMS. The 29C256 is the EEPROM version (the style that doesnt require the UV eraser) is what I need?
Re: BURNER2
if you are going to use the burn 2 get a moates.net d2 and a 29c256
http://www.moates.net/gmecm/g2/G2.htm
http://www.moates.net/g2-memory-adap...cing-p-36.html
Car: 91 Firebird
Axle/Gears: 3.08
Re: BURNER2
Im looking at the 27C256's and some of them say - PC20,70 and 90. Whats the difference or does it matter which one I use?
Car: 91 Firebird
Axle/Gears: 3.08
Re: BURNER2
"If you have a TBI equipped F-Body then you do not need to worry about this because the EPROM plugs directly into the ECM; there is no MemCal. For you '86-'92 TPI owners, there are 3 ways around this. Each method is mentioned below along with pictures. A more detailed explanation of each method follows.?"
Car: 91 Firebird
Axle/Gears: 3.08
Re: BURNER2
sorry, not sure what 27c256 your dealing with hopefully there not otp. I think amd made a flash 27c256 and sst but moates burn 1 and 2 does not support the reprograming of this. you should go with what is know to work and not try to reinvent the wheel.
Car: 91 Firebird
Axle/Gears: 3.08
Re: BURNER2
you're right, I need the 29C256 I typed it wrong on my last post, I purchased the 27's and not realizing that was for the TPI set up. My question is which 29C256 do I need, the PC20, 70 or 90 versions (on ebay it says 29C256-PC20/70/90 and I dont know what the difference is) Having the TBI set up, I need to do all the soldering? According to Traxions tune page the TPI set up is what you were describing not the TBI.
Car: 91 Firebird
Axle/Gears: 3.08
Re: BURNER2
Man if my head wasn't attached to my...
I did actually purchase my burner from moates, he sells the EPROMS too?? I will definitely buy from him!
Re: BURNER2
If your using the G2 adapter it will take both chips or even run a 2732a
I use the 27FS512
http://www.moates.net/c2-sst-27sf512....html?cPath=26
The writeup tuned preformance posted shows the other chip.
I wish everyone would support Moates!!! Even if you could buy a genuine SST 27FS512 chip somewhere else and save .50 cent or even a buck, it's not worth the chance of getting the wrong chip or a counterfiet. All those little 50 cent and dollars add up to keeping him in business to keep making us cool stuff!
He is a pioneer in GM EFI and hacking to get us to where we are today and gave away a lot of hard earned tech!!!
Same with RBob, look at all he has done for GM EFI!!! Buy an EBL!!!
I use the 27FS512
