Vortec head gasket questions
Car: 91 camaro rs
Engine: 305 (350 vortec in dec.)
Transmission: Wc-T5
Axle/Gears: 3.08 (3.42 in dec.)
I have a 305 tbi, I have to deal with it for another four months, I'm buying a brand new 350 (300hp) with 3 yr warranty. I can get a set of vortec 350 heads for $40 here at the junk yard. I wanna use these on my 305 with my new intake, just a small power boost til I can do my swap. What gasket could I use on a set of untouched 350 vortecs, so I can keep my compression (9.3:1) without a mill job, bc I plan to re use these on my future motor. Thanks guys.
Car: 1988 Camaro, 1986 S10, 2000 Harley
Engine: LS6
Axle/Gears: 3.75 9" ford trac loc
Re: Vortec head gasket questions
While the Vortec 350 head is good, it's chamber is too large for a 305. You'll more than likely loose power from the drop in compression. Buy the heads and save them for the 350.
Car: 91 camaro rs
Transmission: Wc-T5
Well my car smokes do to valve seals, on crank up and take off. I was not going to try to replace the seals, maybe I'll just buy a set of regular heads as well, just to get me by.
84z96L31vortec
08-20-2017 12:16 AM
NinjaNife
08-23-2015 11:49 AM
84z96L31vortec
08-10-2015 08:27 PM
