350 tbi with vortec heads and intake
Car: 1992 Pontiac Firebird Convertible
Engine: 5.0 TBI
What kind of power will I make if I take a stock 350 tbi shortblock and added cast iron vortec heads (1.95 valves with 175cc intake runners) and the aluminum vortec intake manifolds with a proper tune?
Also if I added a nice cam what would the results be?
Car: 91 Camaro RS
Engine: 355 Vortec
Re: 350 tbi with vortec heads and intake
Probably in the 230-250 fwhp range depending on exact parts used. Adding a bigger cam/ headers/exhaust depending on parts used can get you up to a little over 400 fwhp, then the vortecs start running out of air.
Car: 91 Camaro RS
Engine: 355 Vortec
Pretty much following the suggestion you see in some of the stickies above. Was not to bad to get it to run, but took a lot of time to fine tune it. Still occassionally notice things and make changes.
84z96L31vortec
08-20-2017 12:16 AM
L98GTA87
08-11-2015 06:55 PM
