454 TBI ?
Car: 88 V6 'bird/89TBI bird/85 T/A
Engine: 2.8/TBI/TPI
Transmission: V8 T-5/700R4 x2
Axle/Gears: 3.42 open/2.73 open/ 3.27 9 bolt
Re: 454 TBI ?
They both have the same air flow characteristics, so either will be fine for you.
You know that you will have to bore out your intake manifold to 2 inches, right? And then you will need to put an adjustable fuel pressure regulator so that you can tune it in right.
Engine: 2.8/TBI/TPI
Re: 454 TBI ?
You have a good shot, at any rate!
I'd still bore out the stock intake and use it first; its aluminum and you may find that it gives you more bottom end, which you need for heavy vehicles. You can still port the hell out of it, too!
Then you need to pull the engine, trans, and ECM/wiring and drop it into an 82 Z28!
Re: 454 TBI ?
lol.......Torque I need to pull my other toy to the track..
Doing a new motor for the truck cause I don't have 40Gs
for a new one!!!!!!! A few grand I have so that's where it's going..Kind of a winter project..Really liking the EBM up grade so should be interesting...
Here's a shot of my other toy..
