Dissapointed yet Saprissed at the Dyno
Car: 90 Camaro
Engine: 305 TBI
Transmission: 5 speed
Axle/Gears: 3.42 POSI
I took my 90 camaro 305 tbi 5 speed (3.08 rear) to a dyno yesterday. I was a little dissapointed in the hp but happy when I saw the torqure.
1st run: It was all over the place and the guy didnt print it out because it was so bad.
2nd run: It maxed out at 157 hp and 247 tq (ran best around 65-75 mph in 3rd belive)
3rd run: 154 hp and 250 tq ("" but mainly 70-75 mph)
I would like to know what rpms I was running.
I am also hoping to hit at least 180hp by doing pulleys and adding a new fuel pump and fuel pressure regulator.(IF you dont think possible please add what you think it would take) It currntly only has the K&N air filter and xstream flow top.
Engine: gone
Transmission: gone
Axle/Gears: gone
Re: Dissapointed yet Saprissed at the Dyno
gotta get headers, high flow cat, and a catback exhaust. that will net you the biggest gains in HP without tearing into cylinder heads, camshaft. but those are things you should look into also in the future.
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
That's a pretty respectable dyno run for a stock TBI 305, the motor is only rated 170 hp at the crank. Better than mine was bone stock - 142 hp & 224 lb/ft and max hp at about 4000rpm. Headers and 3" exhaust & high flow cat netted me 12 more hp. Open element air cleaner netted 10 more hp and about 20 lb/ft. After some playing with the ECM tune (EBL Flash), I was able to get the HP to 169 at 4500rm and brought the torque up to 250.
On my most recent dyno run, I promptly broke my motor and am currently finishing up a TBI 383 with Vortec heads and intake, should be running in about a week.
Car: 1983 G20 Chevy
Transmission: 4L60
Engine: gone
Transmission: gone
Axle/Gears: gone
sounds lame fast...lol jk sounds good these motors can be pumped up with the right parts
Engine: gone
Transmission: gone
Axle/Gears: gone
Yup and in my recomendation if your completely stock or near it. your better off going a different direction. LSx, stroker carb'd, or something of that nature. But I love my TBI car so i'll keep chugging along...
Car: 90 Camaro
Engine: 305 TBI
Whoops sorry I forgot to mention about the exhaust.
It is straight piped but the guy did a **** *** job on the passanger side. Instead of bending the pipe he just made it a T and pluged the bottom.
And I do plan on headers forgot to mention that too.
Car: SOLD!!!!!
darn it i need to get mine to a dyno one day just to see.
305 tbi
ultimate tbi mods
hooker headers and y pipe
no cat
magnaflow catback-3"
egr delete
open element
a/c delete
msd coil and module
matched injectors
3.23 rear gear
700r4
injector pod spacer
custom stage 2 tbi chip
305 tbi
ultimate tbi mods
no cat
egr delete
open element
a/c delete
msd coil and module
matched injectors
3.23 rear gear
700r4
injector pod spacer
Engine: gone
Transmission: gone
Axle/Gears: gone
im going to run mid 13's and that'll keep me satisfied enough til my dodge is done.
Car: 1992 Camaro RS
Engine: 5.0 TBI L03 V8
Transmission: Rebuilt 700R4 W/ Corvette shift kit
Axle/Gears: 2:73 open
I'm Impressed with this dyno result. Thats not bad. Makes me Optimistic about this engine.
Car: 90 Camaro
Engine: 305 TBI
Car: 1992 Camaro RS
4500rpm is the rev limit I think.
Car: 1992 Camaro RS
90RSM5,A4LO3 V89.3:15.0 (305)170@4000255@2400TBI3.082400rpm for max tq and 4400rpp for max hp.
Car: 90 Camaro
Engine: 305 TBI
Ive accidently have had mine rapped up past past 6000rpm and my tach is maybe slightly off. (says about 1000 at idle)
Car: 90 Camaro
Engine: 305 TBI
Ive had mine rapped up past 6000+ but my tach might be slightly off (idles about 1000)
1 Post
Car: 1992 pontiac firebird
Engine: 305 v8 lo3 201.5hp and 268.2 tq
Transmission: 4speed 700r4 corvette servo
Axle/Gears: 3.42 disk posi 4th gen rear swap
my 305 tbi dynos at 202 hp and 268 tq to the tires with 2.73 rearend about to be changed to a 3.73 posi very soon if i can get about 250 hp to the tires iwould be good with that and like 300 tq to the tires or better i would be happy with that i have a lt1 cam how hard is it to put in?
Engine: gone
Transmission: gone
Axle/Gears: gone
And a camshaft swap for a novice automotive person is about a 8.5/10 on the hard scale.
But it's doable and if you have time to have your car down I recomend you doing it. because if you take your time you CAN do it and it'll be easier the next time.
1 Post
i know changing the rearend wont give me any power but dam the 2.73 open rear is geting very old a 3.73 would give me a better launch and faster 1/8 mile times right now i have ran a 9.7 1.8 mile not bad but i cant get any better with a 2.73 rearend
Engine: gone
Transmission: gone
Axle/Gears: gone
yup you are correct, I would believe it would dramatically increase your 1/8 mile time. The way you worded it. It made me think that you thought it would increase HP. Get it in already!
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
3.73s in a low revving V8 may actually not help speed the car up that much. Gears are more for when you have a motor that makes its power at higher RPMs. The gears will help you get to your powerband sooner and not bog off the line. With the stock 305, its already giving you most of what its got by the time the torque converter reaches its stall speed.
1 Post
my car is not stock at all its puting down 202 hp and 268 tq to the rear tires and im not sure if a have a 305 tbi or 350 tbi b/c i have raced friends of mine that have a 305 tbi and i kill them from 0 to 75 that the highest we went up to and a friend of mine has a 91 gta l98 and i have more hp than him he's got 193 hp and 272 tq to the tires we r gonna race on 9/11/11 and see who wins hes got a better rearend hes got a 3.23 posi i got a 2.73 open but my car with my new tires dont spin off the line only when i hit 2nd gear it barks the tires really hard since i got a corvette servo and he dont
Engine: gone
Transmission: gone
Axle/Gears: gone
well I think in the 1/8 miles the 3.73's will keep you pretty close to your powerband if you make sure to hit drive. If your not hitting drive then I dont know if thier really that good for it. IMO.
Car: 1983 G20 Chevy
Transmission: 4L60
My van has had 3.08s in it for years and I know it would love 4.56s as well.
darwinprice
17
10-11-2015 11:51 PM
LT1Formula
10-08-2015 08:34 PM
