need picture of tbi with air filter off
Car: 1982 trans am
Transmission: 4 speed
Axle/Gears: 3.08
can someone please post a picture or two of thier tbi intake with the air filter off, i forgot were my vacuum lines are run, and my shop manuel's diagram isnt helping much, thanks in advance
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Re: need picture of tbi with air filter off
There should be a vacuum diagram on the underside of the hood near the front
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
Only the front side. Just happened to have it uncovered for re-routing plug wires. The open hose on the left is the breather which attaches to the bottom of my open element cleaner. The plugged off port on the right is to operate the heat riser off the exhaust manifold, gone now with headers. The rest is as stock.
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Check out post #2 on this
https://www.thirdgen.org/forums/tbi/...cant-find.html
Car: 1982 trans am
Axle/Gears: 3.08
thanks guys this was alot of help, my car is now up and running great
1992 Trans Am
05-10-2023 07:19 PM
eightsixseven
08-14-2015 03:09 PM
