ticking noise.
Old 02-14-2011 | 12:36 PM
bigred75's Avatar
Car: 1992 25th anniversary RS Camaro
Engine: 305 T.B.I.
Transmission: ????
Axle/Gears: ??????
ticking noise.
ok guys, i got another problem. At first i thought it was a bad exhaust leak but the more i listen i dont know if thats what it is. whenever i am accelerating i hear a loud tick comming from the driver side of the motor. i dont hear it though if i put the car in neutral and rev it up. im lost and the noise is getting really aggravating haha. cant stand showing up to my car club with a ton of new camaros and mine ticking its tail off until i let off the gas.
Old 02-14-2011 | 02:23 PM
marine_camaro's Avatar
Car: 90'RS Camaro
Engine: 305 TBI
Re: ticking noise.
I had the same problem took some tinkering to figure it out but what ya might want to check is your exhaust manifolds the bolts holding them on are notorious for breaking and are a pain to fix also check all of tubing for the smog pump stuff they rust through or break easily also and tend to make a ticking type noise I fixed them and no more noise That's my hopefully it helps ya out.
Old 02-14-2011 | 03:18 PM
rich5's Avatar
Car: 91 camaro RS
Re: ticking noise.
rockerarm or flywheel. my flywheel cracked once and it clicked its *** off when at idle and miniml while driving.
Old 02-14-2011 | 03:27 PM
wiweeds's Avatar
Car: 1991 RS
Engine: 350tbi
Re: ticking noise.
Ya, I had the exact same thing it would only tick with a load on the engine. It turned out the bolts on my header were loose.
Old 02-14-2011 | 07:17 PM
bigred75's Avatar
Engine: 305 T.B.I.
Transmission: ????
Axle/Gears: ??????
Re: ticking noise.
i dont think its the flywheel. it only ticks whenever im accelerating not at idle. and wouldnt a rockerarm tick all the time?
Old 02-14-2011 | 07:22 PM
krazefbird's Avatar
Car: 84 Firebird
Engine: currently 1968 307
Axle/Gears: 3.23 lim slip
Re: ticking noise.
I would think rocker arm also....Being that the ticking goes away when you rev, the rest of the engine noise is overcoming it so you won't here it. Also, the motor will be pumping more oil so that will quiet it down a little?
david068513
LSX and LTX Parts
11-15-2015 11:37 PM
meeklay812
10-01-2015 03:46 PM
corey8084
09-17-2015 02:56 PM
david068513
09-13-2015 11:24 AM
david068513
South East Region
09-13-2015 11:24 AM
Quick Reply: ticking noise.
