l03 heads on an l05?
Car: 1989 Camaro IROC-Z
Engine: LB9
Axle/Gears: 3.08 G80
so i have a chance to get a running l05 from a friend of mine for cheap. it needs a refresh, but is in good overall shape. seeing as how the l05 has 64cc heads and hte l03 has 58cc heads, would it benefit me to put my l03 heads on the l05 (yeah, ill port em up some and get a good tune). the plan is to run ported l03 heads with an lt1 cam, ls2 valve springs, and 1.6 roller rockers. with a ported stock intake unless i can get a good deal on a used one. any one see any problems with this?
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Re: l03 heads on an l05?
As long as you are not expecting serious power, which I don't think you are, you will be fine. The increase in compression will give you great off idle torque and should supporta solid 250hp+ with a little porting. Tuning will be the key ingredient for this combo
Engine: LB9
250 at the wheels would be awesome, 250 at teh fly wheel would be more than an l98, would it not?
Engine: gone
Transmission: gone
Axle/Gears: gone
haha. Yup possibly. First I wanted to beat 5.0 stangs, then I wanted to beat stock 5.7 iroc's, now I want to beat a 4th gen SS that is close to stock...gotta set a goal!
Car: 91 Trans am
Engine: built 360 TBI
Transmission: built 700r4
Axle/Gears: 10bolt/3.23
Dyno Don, has reported 255rwhp with cleaned, 193 casting LO5 heads + LT1 cam + full exhaust.
Engine: LB9
Car: 91 Trans am
193 LO5 heads have bigger valves and flow better then the 187 LO3 heads, I doubt that .6 increase in CR will make up for the better flow of the 193's.
Engine: LB9
Engine: gone
Transmission: gone
Axle/Gears: gone
The goal of engines is to move air in and out as good as possible. better flowing heads is better than a little more compression. a 9.5 to 1 doesnt mean a motor can breathe at 6000 rpms any better than compared to a 9.0 motor with bigger better flowing heads.
Engine: LB9
what i was saying is, keep the l05 heads, port em up, and put some flat tops in it instead of the dished slugs that come stock
Car: '90 RS
Engine: 377 LSX
I wouldn't spend money on new pistons to "fit your combo". I would keep the stock slugs and work around that. A little porting goes a long way with either the 193 or 187 heads. Ever point of compression is worth about 4% increase in power. That is a lot more than a few CFM head flow difference.
Engine: LB9
Engine: gone
Transmission: gone
Axle/Gears: gone
Car: 91 Trans am
Some later LO5's came with flat top pistons, I would take that LO5 under the lens first.
If the engine is comming apart anyway, there are lot of possibilitys, kinda depend on the budget.
Cheapest is to leave the LO5 as is, 2nd cheapest for around 4hp and 8tq gain should be the 187 with 9.8CR (if they are for free), if chainging pistons there is no point for the 187's.
Edit: I have saved this flow number, from old reserch:
stock 193 int. - exh.
0.100 70.4 - 55.7
0.200 100.2 - 115.6
0.300 145.7 - 125.8
0.400 164.7 - 138.9
0.500 178.9 - 146.8
187 LO3 stock head flow 28 in/h20 pressure drop.
lift_in-----I-------E
.050-----35-----27
.100-----65-----54
.200-----90----113
.300----135----120
.400----158----133
.500----165----140
0.100 70.4 - 55.7
0.200 100.2 - 115.6
0.300 145.7 - 125.8
0.400 164.7 - 138.9
0.500 178.9 - 146.8
.050-----35-----27
.100-----65-----54
.200-----90----113
.300----135----120
.400----158----133
.500----165----140
Last edited by thomas1976; 02-12-2011 at 07:18 AM. Reason: stock 193 + 187 flow#'s
Hotrodboba400
12-10-2019 07:07 PM
92projectcamaro
01-18-2016 08:00 AM
