egr delete questions
Car: 70 Chevelle
Engine: 396
Transmission: TH350
Axle/Gears: 10 bolt 3.73
so today i did the egr delete. now i got idling problems.
i know they say you need like an ecm tune so the check engine light goes out but when i did mine i plugged the vacuum hoses and no light comes on but
why am i idling at like 2k rpm then it goes down to 1500 rpm? i need help fast please and thanks
Engine: gone
Transmission: gone
Axle/Gears: gone
Re: egr delete questions
first off why did you do this? and if did you put a block off plate on the egr hole? cause otherwise you just have a big giant vacuum leak.
Car: 1986 Camaro Z28 IROC-Z
Engine: 350 Tuned Port Injection, for now.
Axle/Gears: Posi - 3.23
you NEED TO REPROGRAM the PROM! PERIOD. The programming involves maxing out a value which makes the ECM think that the EGR system is working properly. BUT you may run into problems. I want to ask you something. Y do u wanna delete the EGR? The EGR benefits your engine. It ijects exaust into the cylinders to reduce the upper cylinder temperatures. If the upper cylinder temp gets too high, you can run into issues such as detonation, engine knock, and pinging. This will result in the ECM retarding the spark which will lower your performance. As we all know, deton., ping, and knock can destroy a block. I would seriously reconsider your mod. Besides, it will cost you money to reprogram your PROM. Or you can buy the Moates G1 adapter and have someone program a blank EPROM for you. But then agian, they can charge you a lot.
One more thing, removing the EGR system is not really deleting it. Its removing key components and maxing out the value of the the EGR value in celcius.
Car: 91 Trans am
Engine: built 360 TBI
Transmission: built 700r4
Axle/Gears: 10bolt/3.23
In this case you just did the worst and most useless mod to your car.
Though if it's only a track car, EGR was not active anyway, except when crusing to the track.
For the tune you just deactivate EGR in the calibration loaded in the chip.
Car: 91 Trans am
I have learned, to set the EGR enable themperature wery high in the bin. (for VE learning), this keeps the EGR inactive. Until the engine starts burning
Car: 70 Chevelle
Engine: 396
Transmission: TH350
the engine is screwed up anyway. no need to freak out about a crappy 305 TBI anyway. this thing runs very awful idles really high and backfires in upper rpm even before i removed the broken old bent up egr valve.
should i rip it apart and put a rebuilt 305 in or should i just park it and finish my 355 build?
Car: 70 Chevelle
Engine: 396
Transmission: TH350
Car: 70 Chevelle
Engine: 396
Transmission: TH350
Are you sure you talking about the EGR? you sure you know what and were the EGR is?
Car: 91 Trans am
Chances are the 355 will not run any better, if the issue is not longblock related.
Do you have a steady SES light when the car is on? If so, pull the TC codes.
Car: 70 Chevelle
Engine: 396
Transmission: TH350
no the light doesnt even come on i know that it works because it was always on before i changed oil plugs and pulled egr. the onlything its doing is idling at like 1700-2000 rpm. i think its something with the vacuum lines cause theres a few that are open
Engine: gone
Transmission: gone
Axle/Gears: gone
Yes a vacuum leak will deffinately cause this that is why i asked if you installed a block off plate. you did so that is good. But if you have a different vacuum leak hopefully you didnt drive it too long dont want to run lean for too long. Can burn up the engine.
Car: 1986 Irocz
Axle/Gears: 3.25:1
The EGR system does not activate at idle, so it would have no effect then.
Stop worrying about your EGR and fix your vacuum leaks.
Car: 1986 Irocz
Axle/Gears: 3.25:1
His EGR is gone. Who exactly are you trying to convince here?
He has IDLE problems and is asking for help, but getting nothing but bad advice and irrelevant opinions concerning his EGR system.
People that run EGR often have problems with idle due to the EGR system malfunctioning, but he has eliminated this possibility.
You are sounding like the EGR police.
California - LOL
jumpmanm23 (08-11-2024)
California - LOL
California - LOL
"The EGR system does not activate at idle, so it would have no effect then. Stop worrying about your EGR and fix your vacuum leaks. "
l
l
l
l
Thats good advice that you are providing him!!!!!
If your not gonna try to give the guy good advice, then sit down.
"People that run EGR often have problems with idle due to the EGR system malfunctioning, but he has eliminated this possibility. "
R U sure about that? The vacuum which is high when idling is created by the pistons down stroke as it pulls in atmospheric air. Throttle Plates are closed and the only source for a controlled idle is done by the IAC Valve which works in steps via ECM. If the IAC solenoid is working correctly, then idle should be steady. Of course there are other factors involved to maintain the idle. Now as the engine heats up, the intake heats up aswell through convection. When the intake manifold heats up, through convection, the EGR Valve heats up aswell as the EGR Temp Sensor. As the EGR Temp Sensor heats up, the little element insidde curves and grounds itself out inside the little container. As soon as the EGR Sensor (rather temperature switch similar to the Coolant Fan Switch) grounds out, the ECM see's the closed curcuit. When that happens, the ECM sends a small current to the EGR Solenoid. As the solenoid opens up the valve within the EGR Solenoid, vacuum is then applied to the EGR Valve. As the EGR Valve opens the port, exaust fumes then enter the intake manifold and down into the cylinders.
There you go. thats how the EGR works in a nut shell. So 305sbc, dont talk to me like I dont know what Im saying. Atleast Im trying to help out the guy. What are you doing? Absolutely nothing! You basically told the guy to suck it up and drive on. Some advice you got.
305sbc, I got something for you .
So then check the resistance on the fuel injectors. Our OBD1 systems are as advanced as the newer cars. Newer cars with OBDII systems had the ability to detect which cylinders where misfiring either due to bad coil pack, bad spark plug/wires, or bad fuel injectors. Pull each fuel injector connector and measure the resistance in ohms. Then come back and let us know the resistance values. Driverside from front to back are numbers 1,3,5,7. Passengerside cylinders from front to back are 2, 4, 6, 8. I had terrible idle until I bought a set of Bosch III's. My idle was smoother and throttle response was crispier. Good luck man.
Engine: gone
Transmission: gone
Axle/Gears: gone
BlackphantomZ28
08-21-2015 07:12 PM
