Black Piece?!?!
Old 09-19-2010 | 10:35 AM
Josh4036's Avatar
Black Piece?!?!
I attached a picture with the black piece circled. I have no clue what it is but when my car gets up to temp its starts to let water out the top along with steam. Can someone tell me what the heck it is so i can replace it or fix it.
Old 09-19-2010 | 11:19 AM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Black Piece?!?!
It's the heater diverter valve. The vacuum line on the top runs to the heater controls - when you have the slide set to WARM the diverter valve opens and allows hot coolant to circulate through the heater core, when slid to COLD it closes and the coolant bypasses the heater core.
Part No. 74805 at Advance Auto, $16.99
Old 09-19-2010 | 11:44 AM
1991L98G92's Avatar
Car: 91 Z28 24th Anniversary
Axle/Gears: Posi 3.23
Re: Black Piece?!?!
I think you have in backwards...flows hot water all the time execpt..when set to MAX A/C...it closes and doen't allow hot water to the heater core for max cooling.
Old 09-19-2010 | 12:59 PM
Josh4036's Avatar
Re: Black Piece?!?!
ok so why is it letting coolant out and steam?
Old 09-19-2010 | 01:33 PM
Car: 1992 RS
Engine: Carbed 350
Re: Black Piece?!?!
Because it's broke - it's just plastic, coolant is HOT, heat kills plastic.
Old 09-19-2010 | 02:49 PM
Doom86's Avatar
Car: '86 Z28, '91 RS
Engine: 305ci, 305ci
Transmission: TH200c (no kidding), TH700r4
Axle/Gears: 2.73, 2.73
Re: Black Piece?!?!
I think he's right honestly.
It works off of the cold/warm control if I'm not mistaken.
Old 09-19-2010 | 06:43 PM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
Re: Black Piece?!?!
Yeah that's what it is. I hate those damn things. I keep one in the back of my car. plastic gets brittle and breaks. usually have to change mine once every 2 years.
Old 09-19-2010 | 07:38 PM
1991L98G92's Avatar
Re: Black Piece?!?!
The A/C Vent Heat Defrost lever has the vacuum control valve connected to it, so when you change from the different settings it controls where vacuum is sent. The temp lever only controls the "Blend Door" that blends either outside air or A/C air and heater air
Set your A/C to Max
drive your car and let the air get cool.
put the temp setting to full warm
All that should come out of the vent is the temp of the air circulating inside the cabin
then set the A/C to Norm or Bi-level
Your temp out of the vents will get warm
If your system works any other way than that, your system is not functioning properly
1992 Trans Am
05-10-2023 07:19 PM
Vintageracer
01-10-2020 05:33 PM
IROCZDAVE (88-L98)
10-06-2016 09:08 AM
1Aauto
Sponsored Vendors
09-02-2015 01:35 PM
IROCZDAVE (88-L98)
08-06-2015 03:51 PM
Quick Reply: Black Piece?!?!
