TBI throttle body advice
Car: 92 Camaro RS
Engine: 305 TBI
Axle/Gears: 10 Bolt 3.42 Posi
Just did a throttle body cleaning and used a rebuild gasket replacement...after wards started the car and check engine light stays on....car runs like rally strong, like it has alot of power without giving any gas... at park or neutral it will stay around 1100 rpm and fuxes a tad bit up and down...wondering if I got the TPS with the cleaner and ruined it?
Car: 1992 Camaro RS
Engine: Rebuilt 350 going in after paint
Transmission: WCT5, 7k & counting behind the 350
Axle/Gears: 4thgen disc rear w/ 3.73 Posi
Re: TBI throttle body advice
Sounds more like a vacuum leak to me. I have TBI in my 94 GMC Sierra and it did the same thing the first time I rebuilt the TBI. Check the IAC passages for carbon/gunk preventing a good seal. Make sure the IAC motor is working properly as well and opening/closing properly.
Car: 82 Camaro Z28, 88 IROC-Z
Engine: 5.0L TBI., 5.7TPI
Transmission: Auto TH200C, 700R4
Axle/Gears: 3.23 posi, ones that rotate!
When you put everything back together on the engine, did you verify the TPS setting? If you took it off the TB during the cleaning rebuild, it will need to be re-calibrated
Car: 75 Beast
Engine: 383 +EBL Flash
Axle/Gears: 4.11 with 33"
The TPS on your car is a non adjustable sealed unit - dunking it into the carb cleaner will not hurt it.
You need to do couple of things.
1) Since you have SES on - pull codes by shorting pins A&B on ALDL connector. This way you will know which DTC ECM has flagged.
2) If you have removed and disassembled TB the IAC needs to be reset. There is a procedure how to do this in technical articles on this board.
3) High idle can be attributed to a vacuum leak or non functioning IAC stuck in fully open position.
Do these simple checks first and post your findings.
//RF
Car: 92 Camaro RS
Engine: 305 TBI
Alright Its 100% cured, no more code...smoother idle than before I did the overhaul, happy car...happy owner... I took 82Crossfires advice on the TPS, insted of bringing it in for a re-cal. I bought one from advanced for around 30 bucks, the manager said its pre calibrated...poped that sucker in started the car and pure happiness. hope this helps someone in the future. Thanks everyone
evilstuie
01-09-2020 08:29 PM
mdtoren
08-16-2015 05:45 PM
