350 tbi swap blown fuse
Old 08-21-2010 | 05:38 PM
L98wit's Avatar
Car: 91 rs
Engine: 350 tbi with EBL
Transmission: t56!
Axle/Gears: 2.733
so i did the 350 swap and my gauges fuse keeps burning up first it was when i turned on the air(i hav no AC) and then it starting burning when i connected my laptop to the cars ebl. now it just burns when turning on the ignition. is there a ground that i might hav missed or a wire that i should look into? any ideas
Old 08-26-2010 | 06:10 PM
L98wit's Avatar
Car: 91 rs
Transmission: t56!
Axle/Gears: 2.733
Re: 350 tbi swap blown fuse
can i use one of the accessories slot and switch the cable to power the gauges instead?
Old 08-27-2010 | 11:29 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Does the gauge fuse also power the cigar lighter? If it does I've had problems with the lighter socket. The actual lighter portion has resided in the console for years due to this. As it will blow the fuse from shorting out the socket.
Others here have also had issues with the lighter socket doing the same thing.
RBob.
Old 08-27-2010 | 09:34 PM
L98wit's Avatar
Car: 91 rs
Transmission: t56!
Axle/Gears: 2.733
i never had a cap for the cig lighter and i decided to disconnected ac wires (cause i have no ac) and now the fuse last a little longer like a 10-15 min drive
Ghettobird52
07-05-2024 11:18 PM
MustangBeater20
10-29-2022 09:20 PM
BRoss99
12-07-2020 06:50 PM
xkingcodex
02-12-2020 07:43 PM
camaro11j
09-19-2018 08:49 AM
Quick Reply: 350 tbi swap blown fuse
