350 injectors
Car: 1987 GTA
Engine: 383 HSR
Transmission: 4l60e
350 injectors
I'm needing 2 350 injectors for my swap so I found this set on ebay but I'm wanting to know the lbs/hr on the TJ7 injectors also is this to good to be true for this price??
http://cgi.ebay.com/ebaymotors/89-90...Q5fAccessories
Car: 1987 GTA
Engine: 383 HSR
Transmission: 4l60e
Re: 350 injectors
I've searched and searched and it seems people like buying injectors not knowing the flow rate, anyone know about these injectors? I'm guessing they are 55lbs but i'm wanna be 100% before I buy.
Re: 350 injectors
350 5.7L ORG/BLK 61#/HR
GM5235206*RPD
That post was from RBob...
Here is the thread......https://www.thirdgen.org/forums/diy-...d-up-5-7l.html
Note TJ7 are not GM. Aftermarket? But you are correct. Price is right.
GM5235206*RPD
This is a brand new PAIR (never installed) (Part # TJ7)
1 Post
Car: 91 Trans am
Engine: built 360 TBI
Transmission: built 700r4
Axle/Gears: 10bolt/3.23
Re: 350 injectors
No need to change from 55 to 61 injectors, flow capacety is too similar, just ad some fuel pressure with your stock 55 injectors.
If 55 will not deliver anough fuel with adjusted fuel pressure, you will probably need bigger then the #61/hr.
Car: 1987 GTA
Engine: 383 HSR
Transmission: 4l60e
Re: 350 injectors
I'm not switching from 55lb to 61,lb I need 350 injectors unless I want to run 305 injectors in a 350
1 Post
Car: 91 Trans am
Re: 350 injectors
-65 injectors @ 12psi flow 124.9 #/hr, good for aprox. 236hp
-61 injectors @ 13.5psi flow 124.4 #/hr, good for aprox. 235hp
-55 injectors @ 17psi flow 125.8 #/hr, good for aprox. 238hp
Hope you understand it now.
Re: 350 injectors
That thread I alluded to above somewhat explains GM injectors can be run at higher fuel pressure. Just need to be assurred your fuel pump and regulator(spring) can support higher pressure. You may need a TPI pump and replacement spring if higher than 13 lbs at WOT is needed to fuel motor.
Eric-86sc
08-24-2015 09:01 PM
