305 TBI hesitation??
Old 08-08-2010 | 07:58 AM
92FBirdVert's Avatar
Car: 1992 Pontiac Firebird Convertible
Engine: 5.0 TBI
When picking up speed slowly the car kinda hesitates/surges a little. When I'm in overdrive running around 50-60 mph the car likes to hesitate/surges. But when I pick up speed harder it doesn't do it or when Im in overdrive if im running 65mph or above it will not do it. what could this issue be?Please help
P.S. its a 1992 firebird conv. 305 tbi automatic all stock
Old 08-08-2010 | 08:31 AM
zipfast's Avatar
Car: 94 9c1 Caprice
Engine: LT1 (3-fity)
Transmission: 4L60E reBUILT
Axle/Gears: 3:08 POSI (out)
Re: 305 TBI hesitation??
If it is at one speed range, I would check to TPS first (you can check with a meter).
There's how too's if you search.
Old 08-08-2010 | 08:36 AM
Engine: 5.0 TBI
ok I'll try that thanks
Old 08-14-2010 | 12:27 PM
Engine: 5.0 TBI
I just went ahead and changed the TPS and it wasn't it
Old 08-15-2010 | 01:09 PM
xch3no2's Avatar
Car: 89 K3500 Fleetside
Engine: RAT *tbi* EBL
Transmission: TH400
Axle/Gears: 3.73-Dana 60
Surging at cruise can, among many other things, be caused by EGR malfunction.
From your two threads it sounds like you are running lean under various conditions. Time to check the fuel pressure.
Dwayne614
09-28-2015 08:33 AM
Bubbajones_ya
08-28-2015 02:17 AM
CamaroGuy350
08-26-2015 05:11 PM
Quick Reply: 305 TBI hesitation??
