New or Refurbished Throttle Body?
1 Post
Car: 1988 Chevy Camaro
Engine: 305 TBI
Axle/Gears: Posi
I've been looking around for a new or refurbished throttle body for my '88 Camaro, but haven't been able to find any. The mechanic said that mine has a rod that has gone bad (sticky accelerator pedal) and that I should stay away from used ones because they could have the same problem. Can anyone point me in the right direction of where to find a new/refurb throttle body?
1 Post
Car: 91 Trans am
Engine: built 360 TBI
Transmission: built 700r4
Axle/Gears: 10bolt/3.23
Re: New or Refurbished Throttle Body?
Turbocity http://turbocity.com/ does wery nice work too, I sent mine in and it came back like this http://www.chevyhiperformance.com/te.../photo_05.html new bushings, new shaft, ... new everything.
Here You can see a little of it https://www.thirdgen.org/forums/post...761-post2.html
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
The throttle shaft bushings must be worn really really bad. Used are always somewhat worn, but many are still in good usable condition, depends a little on your budget or preferences. I can send you a pretty clean used one still quite usable for $25, and you could even get it rebushed if you wanted. Just another option. LMK
How much did that cost?
1 Post
Car: 91 Trans am
Can't remember exactly, not cheap but it was resonable.
Could send them an e-mail for a quote.
1 Post
Engine: 305 TBI
Axle/Gears: Posi
Do you know anything about them, if they're good or not? Also, would the chip need to be reburned to handle a higher flowing throttle body?
Terrell351
06-13-2021 01:13 PM
mdtoren
08-16-2015 05:45 PM
