Car won't rev
Car won't rev
Did an engine swap from 305 to 350 and when we plugged everything back in the car idles fine but will not rev.. Injectors don't dump more gas when you press throttle. Changed knock sensor and ESM injectors and new prom... is the ECM bad?
Re: Car won't rev
yes there are no codes and even with the factory prom I am having the same problem.. I've swapped injectors and everything.. can't get the car to move... does anyone know a specialist in Atlanta GA
