Taped up vacuum line.
Car: 1987 Camaro Iroc Z28
Engine: 350 S/B
Transmission: 700 R4
Axle/Gears: 2.43 Gear Ratio
I was chasing my vacuum lines today to look for cracks due to eratic idle and surging engine. I found a small plastic line coming off my TBI to my EGR solenoid that has apparently been taped with electrical tape. The tape is tight and still looks ok but this would most likely leak would it not? And next question is can this line be replaced?
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
Re: Taped up vacuum line.
vacuum tube is cheap , if in doubt replace it . good luck .
Car: 89 Camaro RS
Engine: Built 357 Vortec
Axle/Gears: 3.23 from an '87 iroc
I used shrink wrap (like the black stuff for wires) on that same vacuum line and it works fine. It was originally gonna be just a temporary fix, but it works and im cheap lol
Pac J
05-17-2020 10:44 AM
HoosierinWA
10-07-2015 10:15 AM
