edelbrock performer intake vs bored stock 350 tbi intake
I am thinking about getting an edelbrock performer intake for my 350 tbi in my 89 formula. Is it worth the money or am I better off buying a used stock intake and getting it bored. Will it be about the same cause I do not care about the brand name intake. I can make the stock one look just as good. Just trying to save a dollar cause I work with someone who will bore it for me. Let me know what you think.
1 Post
Car: 91 Trans am
Engine: built 360 TBI
Transmission: built 700r4
Axle/Gears: 10bolt/3.23
Re: edelbrock performer intake vs bored stock 350 tbi intake
https://www.thirdgen.org/forums/tbi/...bi-3704-a.html
If you can find a used 3704 for a good price It could be worth it.
Car: A lot and 86' Z28 and 88' Camaro
Engine: 305, 383 and 565
Transmission: 700R4, th400 and 4L80
Axle/Gears: Frd 8.8 /3.27 and S60
Car: 94 S10 soon to be 305TBI, 01 Blazer
Engine: 4.3 TBI, 4.3 CPI "01 Blazer"
Transmission: 4L60E's
like in the reply above, does a tbi motor benefit with that cutway between both throttle bores? I posted a thread about this myself, I was wanting to do a little cutway myself with my edelbrock performer eps manifold.
1 Post
Car: 91 Trans am
TBI and the "crossflow hole" are 2 separate things.
No matter what injection system, if the engine is out of air the crossflow will allow a little more air, if more air is not needed the crossflow will probably slightly slow down the incoming air velocity.
Most intake manifolds on the LO3's have a "crossflow hole", though with or without you cant tell the difference, unless you take the TB off and look in the bores.
1 Post
Car: 89 RS, 92 Z28
Engine: 305 TBI, 350 TPI
Transmission: 700R4 Both Cars
Axle/Gears: 3.23 Posi.. 4 wheel disc both cars
My stock LO3 intake had a cross flow cut, my Performer TBI does not have.....
theshackle
09-17-2020 08:26 AM
86IROC112
08-17-2015 02:00 PM
