set timing for a 350 on the harmonic balancer
Car: 1991 CAMARO RS,1997 FORD EXPLORER
Engine: NO MORE 305. 350 NOW
Axle/Gears: 273 NEED NEW ONES
hi i just did the famous swap from a 305 tbi to a 350 tbi i have all the right sensors and a new chip from tbichips. my question is the timing to start it up. i did the top dead center on 1 and the coil to point to one. tbc was on 0 on the timing tab and it started up fine once warmed up it got rough and when i re started it pop thre tbi and even fire. i had it runing for a while checked the timing and i could it even get it in the timing tab area. does any one know what the timing should be? its a 350 tbi crate engine from good wrench. schould i leave it a tdc and at the 0 on the harmonic balancer?
Car: 87 Chevy Short Wide
Engine: 383 Vortec TBI
Re: set timing for a 350 on the harmonic balancer
You need to check it with a timing light and esc connector disconnected to see exactly what your base timing is set at.A digital timing light is better.
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
This is the balancer that came with the engine? You've got the EST connector unplugged to set the timing?
