Edelbrock 3704 compatible with rochester prducts egr ?
1 Post
Car: 1988 Pontiac trans am
i plan on buying the Edelbrock 3704 , is it compatible with the rochester EGR valve or do i have to buy a different one ?
Car: 1983 G20 Chevy
Transmission: 4L60
Re: Edelbrock 3704 compatible with rochester prducts egr ?
I had the manifold bored out and ran a 2" marine 350 TBI unit on it.
I had an issue with low-backpressure from my exhaust setting a code 32 and driving up the NOx emissions though. I put on an aftermarket valve and used a larger than recomeended restrictor washer...Basically I went larger and larger on the washer until the engine hesitated off-idle, then backed up a size. Fixed it right up. No light. Clean emissions...
Night rider327
09-25-2015 04:47 AM
