Stock Air Cleaner assembly; Hot rodding it?
Car: 1992 Formula/2008 Mazda6
Engine: 305 5.0L TBI/2.3L tuned
Transmission: 700R4/5-speed auto
I was curious as to whether I could cut some of the metal out of my snorkel air cleaner assembly on my 1989 Camaro RS. It's a 305 TBI. The attached picture shows what I mean.
I would be doing this for increased air flow, like an open element, but it'd still have all the attachments that are normally on it.
Would this work?
Would this work?
1 Post
Car: 91 Trans am
Engine: built 360 TBI
Transmission: built 700r4
Axle/Gears: 10bolt/3.23
Re: Stock Air Cleaner assembly; Hot rodding it?
Under real driving circomstances, under load you car does run stronger with the the stock air cleaner vs open element (comparing with clean air filters).
Engine: gone
Transmission: gone
Axle/Gears: gone
i hae read the stock cleaner doesnt flow enough air to support 8 cylinders of a 305 at 4500 rpms. i modified my stock one. flow thru top taller filter and a powercharger
1 Post
Car: 91 Trans am
I have read and heard the same things, but have tested and compared with two stock lo3 third gens, no real difference until after some tough driving the stocker had more juice. Though I have not tested wenn they are too cool and breath thru the thermac heather.
I installed an open element on my 88 (305 TBI) it sounds allot better but I am not sure the preformance it all that better. What ever you do, do not cut the factory air cleaner they don't make these anymore plus the way it is made the diry will by-pass the filter. If you want real power install a wynjammer super charger good for 70HP @ the real wheels and cost $2,000.
Best of Luck,
Jack
P.S. Also stay away from the ECK chip upgrades, big waste of money!
Best of Luck,
Jack
Huh...well, I have one other question. Would it be in my interest to purchase an open element? I've been reading some of the threads on here, but it seems to go both ways.
Some say purchase ones, others say stay away and keep the stock air cleaner.
Car: 92RS
Would this work?
Would this work?
You'll suck in HOT air. That's bad for the engine. Do some type of Cold Air Intake instead.
1 Post
Car: 1989 GTA, 1985 T/A
Engine: L98, LG4
Transmission: Slush-o-matic 700R
Axle/Gears: stock and stock
I took a 6X2 inch chunk out of the back of my air cleaner housing on my L03 pickup, then removed the cowl weatherstrip to make a poor mans cowl induction. Along with a K&N, I feel that it did improve performance, however, that is simply by using my "seat of the pants" meter. I don't know if it makes any more power, but I feel that it revs up a little faster. Sounds better anyway. I wouldn't take much more than that out if you drive the vehicle on any cool days, I find on cold days they tend to bog if the incoming air is too cold.
Car: 89 Camaro RS
Engine: LO3 TBI
Transmission: 700R4 => WC T-5
Axle/Gears: 3.42 Open Diff
Does anyone know where to get a dual inlet circular air cleaner without holes for exhaust manifold heat?
Car: 1991 RS Camaro
Engine: 350 TBI
Axle/Gears: 3.42 Posi
You could always flip the lid over to let more air in without cutting the air cleaner.
I have an open element and love it. It sounds better, feels better and there is no doubt it can get more air. You can hear it. They say it sucks in all that hot air, but what you do think the Thermac is doing for you? It ends up connecting your exhaust manifold to your intake anyway heating it up!
1 Post
Car: 91 Trans am
It is only cold anough to activate the thermac at startup. Thermac is to help your engine reach operational themperature quicker.
Car: 1987 Firebird Formula
Engine: 2004 LQ4
Transmission: T-5 WC
In my Trans Am I used the vent on my Turbobump hood as my cold air intake.. Aswell as removing the rear seal on the hood.. Lets some cooler air into the engine area..
I have an open element K&N, I love the way the TBI sounds when you stomp it, and that loud sucking noise is going on.
Car: 1988 SC Convertible
Engine: LT-1
Axle/Gears: 3.23 posi w/PBR's
The stock TBI air cleaner is JUNK. The only reason I keep it around is so I can slap it back on for inspection every year. The way to go is to get an open element with a 3" filter and ditch the gold ring spacer between the TB and the air cleaner. It costs less than $30 and you don't have to hack up the stock one. All this talk about sucking in hot air=. More air is better. The stocker severely chokes the amount of air coming in. If you're worried about heat then pull the rubber strip on the rear of the hood. I live in central Texas where it is 100*+ most of the time and I have never had any issues running the open element. There is a MAJOR difference in the way the car responds with the open element VS. the stocker. But then again I have a decently built 355 and the stock air cleaner doesn't even flow enough to feed a stock 305.
all this talk about "hot air" is driving me crazy....this "hot air" does not effect the "LO3" (low output motor) anways. Try putting your hand on top of the stock air cleaner after its been driven, you can't (HOT!!!!!!!!). The open air cleaner lid is only warm to the touch so it has to be cooler....right?
1 Post
Car: 91 Trans am
Alright, I'll look into getting an open element.
Any suggestions? I heard that the Edelbroc 14" by 3" is good. Part number would be appreciated, as the last time I was in, I found one, but it had some attachment that didn't seem like it would fit right on the TBI unit...
Car: '92 Camaro RS
I'm also interested in doing an open element. I see that summit racing has several air cleaner assemblies. I am interested in either the Summit or the Edelbrock air cleaner assemblies. How do I know which one will fit me 92 305 TBI?
Car: 1991 RS Camaro
Engine: 350 TBI
They are pretty much a standard 14" carb air cleaner. What you should think about is the drop base or not. Some air cleaners you may have to remove the ring on the TBI. I got a drop base Edelbrock one and kept the ring on the TBI. It may rub the stock coil wires.
Car: '92 Camaro RS
According to Summit the Edelbrock dropped base air cleaner is dropped 0.625 inches. Summits brand air cleaner is dropped 1.00 inches. Would the Summit Dropped Air Cleaner have to much drop? The GM Chevrolet dropped air cleaner kit is dropped 1.5 inches, would that be too much?
What I'm looking to know is what would be a good amount of drop, so the filter will not rub on anything?
Engine: LT-1
The flats are the only way to go....ditch the gold ring.
I purchased my Mr Gasket air cleaner at Advance Autoparts (part number 1480). It is a non-drop base and does not interfer with any wires. What ever you do get a non-drop base and get rid of the factory spacer ring that is used to lift the factory drop base.
Advance Autoparts sell other brands also.
1 Post
Car: 91 Trans am
I have tested, and the open element did not better but worse.
Full exhaust, LT1 cam, tuned EBL and CAI will get you 70hp.
To gain 70hp with a SC on a stock LO3, you probably will need full exhaust, tuned EBL and CAI. Though wich SC are you refering to?
"Wynjammer Superchargers" requires a free flowing exhaust upgrade only, they provided an updated chip with the unit. Cost $1945 + S/H not bad and it can be installed in about 4 hours. I don't have the link but there number is 602-971-5554.
Let me know your thoughts
1 Post
Car: 91 Trans am
This may help calculate the hp gains.
https://www.thirdgen.org/forums/tbi/...ercharger.html
The stock ECM is a big problem, I dont think theyr updated chip will do wonders. EBL will.
Car: 84 z28 ttop
Transmission: 700r4 duh
Thomas. I want to know what your method of testing was
Car: 1990 camaro rs
Engine: 5.0L 305 tbi
If you want better looks and throttle response, get an open element. Yes the stock one will give you cooler air but most people ain't picky enough to care, i sure don't. You'll be happy with an open element i think.
1 Post
Car: 1991 RS
Engine: 350 TBI
Axle/Gears: 3.08 lt. slip
I drilled 1 1/2" or 2" (can't remember) holes along the unseen back side of my stock snorkel air cleaner. It works great and looks factory.
Engine: gone
Transmission: gone
Axle/Gears: gone
I went open element with my cowl hood and i love the amount of suck it has.
Car: 1989 camaro RS convertible
Engine: 305 TBI stock
Transmission: 700-r4
sorry to intrude on your message. but i actually installed an open air element today and now while in drive the car kinda lurches forward and just keeps revving up. Can anyone help me on whats causing it to do that. it ran 100% fine before i installed it
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
For the "OP" and his idea,its interesting and to each there own but I would just do the open element because once the holes are cut it defeats the stock units ability to "suck" air from the front of the breather hose. Here's a 14”x3” open element with “Summit Racing “Power Lid” using a 2” Goodmark steel cowl hood to direct a nice steady stream of cool air pulling from the cowl. Its a drop base with the ring and a 1/2” spacer to keep it off the linkage. Instantly helped with throttle response, I also love the sound of the air pulling through the element,and can actually feel it pulling air through the cowl vent. The tone of the exhaust even sounds better . Also during the summer months I remove the hood cowl weather striping allowing hot air to escape.
Engine: TBI,5.0
Also here's a photo of the chrome air breather for the PCV system that was installed after removing the stock unit.
Car: 1991 camaro rs
Engine: 305 TBI
Axle/Gears: non-posi
Question here, new to the site so not sure where to post this but here goes, i have a 91 rs with the tbi, I'm anting to get rid of that factory p.o.s air intake system ontop the the trottle body and replace it with a plenum that sits right ontop of the throttle body for a little more power, but heres my question, there is a sensor on the back of my factory air cleaner housing what happens if thats not hooked up? because theres no place in this plenum for it to be plugged in and im not keeping this factory air cleaner on please help!!!!!
Engine: TBI,5.0
Dose it look like this ?Its a IAT sensor (Intake incoming air temperature sensor.)
If so I was lucky and there was a place to punch out a ring on the base of the new open air element and push it in.
I have heard of it just being secured to a few wires on the firewall and left alone.
Car: 1991 camaro rs
Engine: 305 TBI
Yes thats it, I'm buying a intake plenum from napa or ebay, and custom making my own cold air intake but placing the filter right where the serp belt is so it catches air from my aftermarket electronic fan, heard it pulls in more air that way, although it might be warmer air. hope it runs right. or what kind of air cleaner will i see the biggest power gain? and my next install is headers, whats the easiest way to put those on?
Engine: gone
Transmission: gone
Axle/Gears: gone
Any hoses that were taken off of the TBI unit must be plugged off. That should only be one nipple on the front.You can see it in the third photo above with a little black cap.
#42
Car: 1990 Formula Firebird
Engine: 305TBI w/ Functional Sport Hood CAI
Axle/Gears: SLP Posi and 3.23 Gears
#43
Car: 1991 camaro rs
Engine: 305 TBI
Anyone Have any pics of their custom cold air intakes? i need ideas
#44
Here is what a user who is giving me advice in my intake thread did for a custom cold air intake. Personally I would have made it go to the wheel well and cut a hole and removed the smog pump or relocated the battery.
https://www.thirdgen.org/forums/tbi/...l-diy-tbi.html
The easiest way to do it is to get the functional power bulge hood air box (if you can find one undamaged), like I am running. Pics can be seen here: https://www.thirdgen.org/forums/tbi/...ion-305-a.html
#45
1 Post
Car: 1991 firebird
Engine: TBI 305 (built)
Axle/Gears: 4.10
Here ya go I just did this last week there is a thread I started called "custom TBI CAI"
#46
Car: 1991 camaro rs
Engine: 305 TBI
#47
1 Post
Car: 1991 firebird
Axle/Gears: 4.10
I drilled a hole in the carb hat to insert IAT sensor .. Search custom TBI CAI that thread has a list of parts and instructions
1992 Trans Am
05-10-2023 07:19 PM
86IROC112
09-07-2015 01:37 PM
