Need a source for TBI bonnet
Car: 83 GMC G3500
Engine: 350 w/ EBLFlash and TBI heads
Transmission: TH400
Axle/Gears: 4.56
Well I tried hunting around the auto wreckers for a Cadillac TBI bonnet only 4 cars in the yard totally stripped no luck.
Does anyone know the exact model and year of the FWD Cadillacs that used this system. I know it was late 80's to early 90's but I need the exact year and model so I can maybe order it.
I was looking at some of the TBI intakes on eBay. But I’m worried they will not seal well upset MAF readings and let dust in. Has anyone tried one or found one that works well?
Does anyone carry a OEM or aftermarket bonnet?
16197427 PCM w/MAF hack 83 G3500
Mike...
Mike...
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Re: Need a source for TBI bonnet
Mike...
Mike...
Car: 1992 Camaro RS Convertible
Axle/Gears: LS1 posi/disk 3.42
http://www.partzfinder.com/Spectre_S...p/spe-9841.htm
i just ordered this on monday, let u know how it turns out when it comes in..... delivery date supposed to be the 8-31-09. they have a few others but this was the cheapest one and the cheapest i found online as well
Car: 83 GMC G3500
Transmission: TH400
Axle/Gears: 4.56
Spectre makes one. http://www.summitracing.com/parts/SPE-9849/. Let me know how the rest of the install goes and if you need any help.
Car: 83 GMC G3500
Transmission: TH400
Axle/Gears: 4.56
Does anyone make one with a port for the breather tube.
Car: 88 Camaro SC
Engine: SFI'd 350
I dont think so. What I did was to drill a hole and install a rubber grommet and used a male/male hose barb fitting to hook the hose up to the grommet. I think it was a PCV grommet for a ford ranger and a 3/8" hose barb fitting. Make sure you measure your grommet with the fitting installed in it before you drill the hole. The hole should be slightly smaller to allow a snug fit.
Car: 84 TA / 89 Formula
Engine: LS1 / L03
Transmission: T56 / 700R4
Axle/Gears: 3.73 / 3.27
btw... TBI does usually not have a MAF sensor, i guess you were speaking of the Intake Air Temperature (IAT) sensor..
Car: 83 GMC G3500
Transmission: TH400
Axle/Gears: 4.56
I looked at a Spectre 9841 plenum locally today but I'll order online. They wanted $115CDN plus 12% taxes.
Car: 83 GMC G3500
Transmission: TH400
Axle/Gears: 4.56
This will give me a MAF sensor IAT sensor and a MAP sensor as a backup.
Plus it will look cool
Engine: LS1 / L03
hehe, definately sounds like you know what you're doing
btw, when you get the 9841, could you possibly do some measurements of A, B, C for me like in the attached pic please? i'm trying to find a suitable base for fabbing up an air cleaner assy that can also retain my cowl induction.
thanks in advance
thanks in advance
Car: 83 GMC G3500
Transmission: TH400
Axle/Gears: 4.56
thanks in advance
thanks in advance
thanks in advance
thanks in advance
mine came in but i didnt have anything to measure it with, but from the looks of it, the only way it seems like it would work for a cowl hood(meaning turned around towards the windshield) would be to get a spacer ring and put it under the plenum. it will definately clear the stock hood tho
on another note, its a real nice piece. they even gave me a free t-shirt and it came with a bad too. that was totaly unexpected and even tho the shipping took a couple days longer than summit would have, i am very happy with my purchase from partzfinder.com.
1Aauto
Sponsored Vendors
24
03-27-2018 12:59 PM
1Aauto
Sponsored Vendors
01-15-2016 07:26 AM
1Aauto
Sponsored Vendors
01-15-2016 07:25 AM
1Aauto
Sponsored Vendors
11-09-2015 03:25 PM
