Quick T.B.I supply/return line question
ok im wondering which line is supply and which one is return. if im facing the motor from front is supply on left (pass side)? or vice versa..
thanks guys!!
ok i figured it out, how do i delete my thread?
thanks guys!!
1 Post
Car: 1990
Axle/Gears: stock
Re: Quick T.B.I supply/return line question
when you ask a question and get the correct information, you should also post the answer to the problem so others with the same question will see it.
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
Axle/Gears: 3.42 Posi
For the record, the supply line is the slightly larger diameter line that is on top (where the lines go behind the alternator). The return line is on the bottom.
84z96L31vortec
08-20-2017 12:16 AM
84z96L31vortec
08-10-2015 08:27 PM
