Astro v8 swap ECM question.
Old 07-04-2009 | 04:04 PM
ZachZ's Avatar
I know this is a Camaro web site but it is hand down the webs leader in TBI information, so please don't jump all over me.
I have been searching the site for the last few days and I have a couple questions I could not find answers to.
I have a 1994 Astro van with a 4l60e transmission and 16197427 ecm. As far as I can tell all I need to to to get my 4.3 tbi ecm to work with a 350, is swap the chip right?
And I am a bit confused, I know I need to swap the ESC unit for one from a v8. I have found 2 different models with two different part numbers 16128261 and 16128251. Which spark unit is correct or does it matter?
Zach
Old 07-04-2009 | 04:22 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Re: Astro v8 swap ECM question.
Zach
You 1994 Astro has the newer PCM which does not use an external knock module. The knock sensor is wired directly to the PCM and the knock filter/module is built into the Memcal. I would search for a 1993-1994 Fullsize G-van with a 5.7/4l60e combination in it. Use the memcal from it.
Old 07-04-2009 | 04:35 PM
ZachZ's Avatar
Well that is good to know. So really all I need is a complete 5.7 tbi engine with a 93-94 distributor and a Memcal and I sould be good to go right?
Old 07-04-2009 | 04:41 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
You need a good 5.7 TBI or even a 5.0 TBI, the orange/black 61# injectors, 1993-1996 TBI 5.7 knock sensor for an automatic transmission, and a V8 TBI distributor. I would try to find one with a "369" ignition control module.
If I remember the EGR on your year model 4.3 is a Linear style full electronic unit. You will need to make a small wiring change to use the normal vacuum solenoid controlled unit that is on the 350.
Old 07-04-2009 | 04:46 PM
ZachZ's Avatar
Thanks for the information. This is going to be much eaiser than I thought. When I get to the EGR I am sure I will be back here asking what to do next, but the info you just gave me should keep me busy for awhile.
again!
Old 08-26-2010 | 11:15 AM
Astro man's Avatar
I am looking for the same info reguarding a V8 swap but my Astro is a few years newer, a 1998. Should I be looking fro the same?
Old 08-26-2010 | 04:04 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
You just need the PCM from a 1998 G1500 Express with the 5.7, add a few wires into the harness for you injection, L31 single knock sensor and add the L31 vortec intake setup. EVERYTHING else on your engine will change over, distributor, coil, crank sensor, everything.
fbodyfreakls1
10-06-2015 06:34 PM
Alyn Murray
04-14-2010 06:02 PM
duratothemax
02-07-2008 05:58 PM
Astro Perf.
01-29-2007 08:24 PM
Quick Reply: Astro v8 swap ECM question.
