TBI NOT SQUIRTING?????
Car: 91 CamaroRS convertible
Engine: 305 TBI
Axle/Gears: stock
My car ran fine until I just finished my exhaust and went to start it. The engine cranks but the injectors aren't squirting!!!!I checked and i am getting fuel to the tbi pods but I'm not getting any power at the injector terminals. HELP PLEASE!!!!
1 Post
Car: 92 Z-28
Transmission: THM700R4
Re: TBI NOT SQUIRTING?????
Check fuses? What pods are you talking about and how do you know you are getting fuel to the pods? Did you try and throw a little gas in through the TB throat to make sure that is what your problem is?
Engine: 305 TBI
Axle/Gears: stock
I checked the connection at the injector pods and am not getting any volts. Yes it will fire right up if I put gas down the throttle body.
Car: 1990 Camaro RS
Engine: V8 305 TBI
Transmission: W/C T5
Axle/Gears: 3.08
Make sure the injector pods are "plugged in", if you will, I accidently unplugged one of mine and the one pod stopped firing, it seats itself on a plug of sorts. Make sure you didn't jiggle it loose when you were removing the air cleaner.
Engine: 305 TBI
Axle/Gears: stock
Thanks for the help guys I got her running again.
