Throttle Position Sensor? Bogging down problem...
Car: 1988 Camaro
Engine: 305 TBI
Transmission: 5sp manual
Just recently in my 88 camaro with a 305 I have had a problem with bogging down. No matter what gear im in (its a 5 spd) if you get into it too quickly it bogs way down and doesnt recover until you ease out and back in on the accelerator. If you start out by easing into the throttle it does ok but takes a while to get up to speed. I am thinking its a throttle positon sensor. Any other ideas? Thanks
Car: 75 Beast
Engine: 383 +EBL Flash
Axle/Gears: 4.11 with 33"
Re: Throttle Position Sensor? Bogging down problem...
Hank
TPS - Probably not - but you can easily check TPS with DVM to make sure that it does not have a worn spot at near WOT position. Basically, with engine off, ignition on measure Pin B (backprobe connector, do not damage harness) voltage of the TPS connector relative to ground (Pin A). Voltage should change smoothly from about 0.6 volts at idle to about 4.3 - 4.6 VDC at WOT.
Most likely it is your fuel pump on the last legs. Check TPS as outlined above to exclude TPS out of your trouble tree.
//RF
//RF
Car: 1988 Camaro
Engine: 305 TBI
The fuel pump was just replaced less than 1000 miles ago. This is a restoration car. Fuel Pump was going bad when we got it and we replaced it.
Car: 75 Beast
The only way to get to root cause is to check, measure & verify.
Bad MAP sensor may cause rich condition and loss of power at WOT. Do you have SES light indicating DTC codes??? If not get a paper clip and short pins A&B on ALDL connector.
Even new pumps are known to fail - verify your fuel pressure.
//RF
//RF
9192camaro
16
02-03-2019 12:21 AM
someone972
08-30-2015 12:52 AM
mdtoren
08-16-2015 05:45 PM
