weiand street warrior
Car: 92 camaro rs
Engine: lo3 305 tbi
Axle/Gears: 2.73 , 3.42 soon
What do yall think about the weiand 8126?
This is what they say.
Don't settle for less in the ever-changing performance world: Street Warriors deliver brutal low-end torque and killer horsepower across the 1500-5500 RPM range. With the popularity of larger stroker engines and onset of more efficient cylinder heads and camshafts, the need for intake manifolds to support such combinations arose. The Street Warrior is designed with computational fluid dynamics software and offered with a cast, polished, or Everbright finish.
$170.00 don't sound bad. Has anybody tried one of these? Let me know what you think.
Car: 92 camaro rs
Engine: lo3 305 tbi
Re: weiand street warrior
I had pretty much decided with the performer rpm , but when I came across this it sounds like it is the best for the street. When I put my new topend on Ill let you know. The new top end will consist of ported heads, street warrior intake and 2031 compucam. The bottom end has already been rebuilt. They were suppose to bump the compression up so it should do pretty good. Im trying to get int the high 13's.
