A.I.R. Removal Questions...
Old 08-30-2008, 03:49 AM
nimrod_sixty9's Avatar
Car: '91 RS Camaro
Engine: 5.0 TBI
Transmission: Manual
Axle/Gears: 3.08
1. What belt size?
2. How to plug manifolds? Bolts/Bolt size?
3. Can I completely remove pump without affecting how any other accesories mount?
4. Is this the correct belt routing for my car?
91' Camaro 305 TBI w/out CAT
Please keep on topic. I know its illegal. I know it helps emmisions. I know there is no gain. Yes I searched... Hard to find a specific answer when you have to search through every thread that mentions A.I.R.
Old 08-30-2008, 06:08 AM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
Re: A.I.R. Removal Questions...
#1 , belt size is mentioned in tech article on removing smog pump . looked at my belt , got 6pk2460 968k6 #s from it . #2 , 1/4" NPT , i used internal wrenching/allen wrench plugs on mine . #3 , yes , re-install mounting bolts , 1 or 2 go into block to mount bracket . #4 , yes . good luck .
Old 08-30-2008, 08:38 AM
Car: '91 RS Camaro
Engine: 5.0 TBI
Axle/Gears: 3.08
Yeah I seen belt size in the article, still figured Id ask because many report that it has too much vibration, wanted to hear from someone who had it working well. So thank you for checking and giving the p/n.
Sorry to sound a bit uneducated here, but I dont no what you mean about the plugs. Dummy terms? Where to buy?
Thanks for your help, very much appreciated!
Old 08-30-2008, 09:16 AM
UNCLE TOM's Avatar
plugs are 1/4" National Pipe Thread . available most any hardware store . bigger selection at home depot or lowes . the only dumb/stupid question is the one that is not asked . good luck .
Old 08-30-2008, 01:51 PM
Car: '91 RS Camaro
Engine: 5.0 TBI
Axle/Gears: 3.08
Great, the GF works at HD! Thanks for all your help!
Old 08-30-2008, 04:40 PM
TZFBird's Avatar
Car: 1988 Firebird, 2000 GTP
Engine: 327
Axle/Gears: 9" posi, 4.11
Have fun trying to get those lines out from behind the block. After you get that out of there, you can re-route the heater valve.
All I did was take the hoses off the valve, run them under the AC lines around the drier. Cleans everything up a TON.
Old 08-30-2008, 08:10 PM
Car: '91 RS Camaro
Engine: 5.0 TBI
Axle/Gears: 3.08
Wow that looks great! So much cleaner! Thanks for the pics.
As for the line behind the block, Ive read that people just cut it and just leave it there.
Old 08-31-2008, 10:23 PM
TZFBird's Avatar
Engine: 327
I left mine in until just recently when I started my engine swap. That's when that second pic was taken, but it was cleaned up about that much anyway.
Old 09-03-2008, 11:53 PM
Car: '91 RS Camaro
Engine: 5.0 TBI
Axle/Gears: 3.08
I can see whats missing and I still can tell that it looks much much better. BUt I ahve to ask, did you use the same hoses? Any tips? Looks great and I really want to do it. Thanks!
Old 09-04-2008, 12:51 AM
TZFBird's Avatar
Engine: 327
I used the hoses that were already there. All I had to do was take them off the valve, re-route them, and put them back on. You do have to take them loose on both ends to get the hose to rotate the correct way since they are preformed. While I have the coolant drained, I might go through and make a write-up about it this weekend. If you want to just figure it out, go ahead. Otherwise if I remember I'll try and get something written up with pictures.
Old 09-04-2008, 01:30 AM
Car: '91 RS Camaro
Engine: 5.0 TBI
Axle/Gears: 3.08
"loose on both ends" That is what I was wondering. I was looking under the hood today, and realized the shape of the hoses. And of course I thought they would kink if I moved them the way they were. So that cleared it up.
I await a write-up with great anticipation!
Old 09-06-2008, 07:49 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
I heard Florida is going to be doing smog checks soon, so I hope you didnt throw those parts away. You'll need them to pass.
Old 09-07-2008, 12:20 AM
Car: '91 RS Camaro
Engine: 5.0 TBI
Axle/Gears: 3.08
Not heard of this... I think they killed it all completely in 2000 or 2001...
If you find out something about it please post link, thanks.
Old 09-09-2008, 09:44 PM
Car: '91 RS Camaro
Engine: 5.0 TBI
Axle/Gears: 3.08
Ok new question. The only size that is close that all my local part stores have is 967K6. Thats only .1" smaller, but I figured Id ask before I get it, so is it ok to get or no?
Old 09-09-2008, 10:41 PM
Shift06's Avatar
Car: 1991 Trans Am GTA
Engine: LSX (swapping)
Transmission: 4L60E (swapping)
Axle/Gears: 2.73 Posi 10 Bolt
Yes I am sure your tensioner can make up for .1 of an inch.
Old 09-11-2008, 03:01 AM
Car: '91 RS Camaro
Engine: 5.0 TBI
Axle/Gears: 3.08
Thanks, just wanted to make sure the ten wasnt already pushed too far
Old 09-16-2008, 12:58 AM
Car: '91 RS Camaro
Engine: 5.0 TBI
Axle/Gears: 3.08
Hey, wheres my write-up?
Old 09-18-2008, 01:26 AM
Rockyd's Avatar
Car: 89Z28 Vert
Engine: 350/tbi
Axle/Gears: 3.27 Posi
i got some headers and took off the air and then i just rerouted my heater hoses i cut the on that gos to the heater valve (PLASTIC ) turned it around and plugged it straight into the hearter core and plugged the lower hose looks alot cleaner
Old 09-18-2008, 06:47 AM
Mongoose's Avatar
Car: 90 Formula
Axle/Gears: 9 bolt/3.27
Why not keep your stock size belt and use the AIR pump delete pulley?
Old 09-18-2008, 07:01 AM
Car: '91 RS Camaro
Engine: 5.0 TBI
Axle/Gears: 3.08
Very nice! But Id like to keep everything functional, as everything in my car still works... for now...
Belt is cheaper. And its probably about time to replace it anyway.
Old 09-19-2008, 01:41 AM
Rockyd's Avatar
Car: 89Z28 Vert
Engine: 350/tbi
thats what i want my heater still works the only thing is i dont have the ugly plastic peice there that plastic valve is to divert the coolant from running in the heater core when not in use but like many other cars out there thats fine if it does so my heater works no check engine light on and i still pass emmisions so everything still works on my car
Old 09-20-2008, 01:48 AM
Car: '91 RS Camaro
Engine: 5.0 TBI
Axle/Gears: 3.08
Doesnt that affect A/C operation though?
Old 03-07-2009, 10:21 PM
Al90IROC6's Avatar
Car: 1990 Chevy Camaro IROC-Z
Transmission: TH700r4
Axle/Gears: 3:73:1 posi
Who has that belt because I went to Autozone and they do not carry that one.
GeneralIesrussi
Carburetors
06-20-2024 07:21 PM
HP52TA
02-03-2018 10:51 PM
MY87LT
Aftermarket Product Review
06-07-2016 09:47 PM
ctoledo0834
09-18-2015 04:16 PM
Stroopwafel
09-11-2015 06:38 AM
Quick Reply: A.I.R. Removal Questions...
