how do i get 300HP
Car: 90 camaro rs
Engine: LO3 305 tbi
Axle/Gears: 3.42 posi
how do i get 300HP
Hi I have a 1990 camaro rs v8 305 and I and wondering what the best way to get this engine to 300HP. Its a tbi engine. All help appreciated
Car: 1992 Firebird
Engine: 350TBI
Axle/Gears: Ford 9in 4.10
Re: how do i get 300HP
Just search around on here. All the info is available.
heads, cam will get you too upper 200s easily with a good tune.
Car: 1986 Camaro Z28
Engine: 400
Axle/Gears: 10 bolt Posi 3.73
If you're going to tear it down and go with heads and a cam, you might as well go with a 350 or larger. Unless you can't for some reason.
Car: 82 camaro sc
Engine: 355 SBC
Axle/Gears: ford 8.8 3.73
.234 dur .490 lift cam casket match ur intake manifold. polish throttle body. port and polish ur heads. roller rockers. that should get u started. do u want 300 to the wheels or too the crank?
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
That depends on what cam you put in. The stock one will be around 1600 RPM or so with a modded motor. Maybe 2000-2400, depending on the cam.
Car: 90 camaro rs
Engine: LO3 305 tbi
Well what size cam and stall converter will make for a much more powerful take off at a reasonable price?
Zeek1041
Theoretical and Street Racing
09-30-2015 11:00 AM
