Recommended coil for 92 bird 305 tbi?
I am looking to get a better than stock coil for my 92 bird. I changed the plugs last spring (NGK Iridiums) and changed the distributor cap and rotor button last year as well. This year I changed the wires (Mallory 8mm high perf) Any recommended coil? I was looking at this one: http://store.summitracing.com/partdetail.asp?autofilter=1∂=ACC-140011&N=700+4294924927+4294908153+4294907958+4294840138+400020+115&autoview=sku
Car: 89 Camaro Convert,89 Camaro hardtop
Engine: 305 and a 357
Transmission: 700R4,T5
Axle/Gears: 4.10's and 3.43's
Re: Recommended coil for 92 bird 305 tbi?
ive got a msd blaster coil paired with a msd pro billet dizzy i noticed a little more throttle response
1 Post
Car: 1991 Chevy Camaro RS
Axle/Gears: 3.73 w/SLP Zexel Torsen Limited Sli
Got an Accel 300+ digital ignition comes with a coil(multi strike setup) specific for it. love it had it on my 87 LG4 before i swapped a 350 and i got me better throttle reponse and 4 mpg improvement 14 to 18mpg.
Engine: gone
Transmission: gone
Axle/Gears: gone
all i konw is when i first put my motor in my car about 2 months in i changed the coil to a MSD stock replacement type coil, the cap, rotor, plugs, wires were all new. and i had coil meltdown in 15 mins. the connections were all good. im thinking it had to much free flow for the stock ignition system to take so it backed up into the coil making it hot and melted it down. Ive never had much luck with any aftermarket coils besides the mallory promaster i have in my charger.
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Your stock coil is just fine. Unless you have reason to believe that it is bad, keep it and save the $50 for something else.
Engine: gone
Transmission: gone
Axle/Gears: gone
if stock is all you want then id buy an acdelco col.
Car: 91RS, 91RS
Engine: 305TBI, 3.1MP
Transmission: WCT5, TH700
I waited until my stocker went out and bought an MSD GM Blaster. It just plugs into the factory connections. Seems like it helps combustion somewhat, but that could also have been my OEM piece getting weak over time.
