Help! Need 60100 VooDoo Cam Card info!
Car: 88 Camaro
Engine: 305TBI
Transmission: Stock
Axle/Gears: 3.42?
Does anyone have a cam card for the Voodoo 60100 cam?
I need the cam card info , I can find the full specs anywhere
Please help
Please help
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
Re: Help! Need 60100 VooDoo Cam Card info!
What part of the specs are you looking for?
From the Voodoo Catalog I have
60100 60100LK 250/256 207/213 .437"/.454" 112/108 Hyd/Hyd
If there is something specific you need, I can try to find it, with that info you should be able to figure everything else out, based on that info.
Car: 88 Camaro
Engine: 305TBI
Transmission: Stock
Axle/Gears: 3.42?
Hey Dewey thanks for the offer. The info I need is the valve timing specs:
at .006 intake valve opening BTDC and ABDC abd the .006 exhaust valve opening at BBDC and the exhaust valve closing at ATDC and also the lobe lift for intake and exhaust if you have it
Thanks a million
I have an old desktop dyno and can't get accurate numbers without it
Thanks a million
Car: 1990 Camaro RS
Ok here you go.
First, for anyone else who comes across this, you can calculate this stuff manualy, but EVERYONE should have this tool on their PC.
http://www.empirenet.com/pkelley2/DynamicCR.html
That is the dynamic compression calculator, since the valve events are needed in that calculation, it comes with a tool to calculate out all your valve events. It is an awsome tool!!!
So for this cam, what we get is.
Intake: Open: 17* BTDC Close: 53* ABDC
Exhaust: Open: 64* BBDC Close: 12 ATDC
Overlap: 29*
Hope that helps!
Overlap: 29*
Hope that helps!
Car: 88 Camaro
Engine: 305TBI
Transmission: Stock
Axle/Gears: 3.42?
Thanks a million
This is great, This will be a huge help in the future
junkcltr
08-02-2019 11:12 PM
