Part numbers: Air hose and EGR vacuum tubes
What ever happened to Trickster? Remember that guy? He was awesome... always had a diagram and part number on hand for whatever you needed.
I miss him.
Anyway, does anyone have any idea where I can find the part numbers for the vacuum tubes that run the EGR and also connect to something on the base of a 305 TBI unit? I've attached a pic of the busted up parts I have that I can hopefully source tomorrow. Part numbers would be gravy.
Thanks!
I miss him.
Thanks!
Car: 1992 Camaro
Engine: 5.0L TBI
Re: Part numbers: Air hose and EGR vacuum tubes
Sorry, no parts number, but a quick fix solution.
Same thing happen to me and I just used some rubber tubing to connect the broken tubes. It has held up for about a month now, no problems.
Car: 91 Trans Am
Engine: LSA
Transmission: T56 AWD
Axle/Gears: 8.8 4.10
Parts stores sell vacuum hoses in various sizes
Id replace the whole line with this but you can successfully slip a short section of hose over the break to seal the old lines
1992 Trans Am
05-10-2023 07:19 PM
