454 throttle body - air cleaner fitment questions..
Old 12-02-2007 | 08:54 AM
Tbi-MAX's Avatar
seems like the parts stores dont have any elements to fit my TBI 454.. what size elements are you guys with the BBC throttle body using? and anyone have pics of a BBC tb stock snorkel?
i believe i need atleast 3.5" to clear the throttle body itself, or maybe even 4"...
Old 12-02-2007 | 09:30 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: 454 throttle body - air cleaner fitment questions..
If you are having a height issue with the air cleaner, GM used spacers on many different vehicles of various heights. From something like 1/2" through 3". Can even stack them. Cars typically used the shorter spacers while trucks used the taller ones.
RBob.
Old 12-02-2007 | 10:56 AM
Tbi-MAX's Avatar
RBob.
its not really a height issue, i have plenty of room under my suburban hood.. i also use the 1 3/4" heater riser for the BBC tb.... but i cant find a open element, that will clear the bbc throttle body injector pod, and still bolt shut..
Old 12-02-2007 | 02:17 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Not a problem, the spacers I was referring to go on top of the TB unit. IOW, between the top of the TB and the bottom of the air cleaner.
IIRC, there is an air cleaner element that is 14" dia and 4" tall. Not sure of the app.
RBob.
Old 12-02-2007 | 05:06 PM
oldred95's Avatar
Even the stock air cleaner housing should still fit. The pods are no different. I guess I don't get where the clearance issue is.
Old 12-02-2007 | 06:50 PM
Tbi-MAX's Avatar
well the stock was dual stud.. the 454 tb was a single stud.. plus i sold my dual stud and tb spacer... so i got rid of my stock chopped up snorkel i made a element.. but b4 i got rid of it, i tried to fit the stock collar/spacer that the breather plugs into.. and it wouldn't even fit over the 454 tb.. it was a tight fit, and if anything hampered air flow..
RBob.
i got a WIX 14x4 element for my application, with a new open element caseing.. it looks great.. and cleared the throttle body just fine.. thanks! the open element is HUGE.. ill try to post pics tmrw..
Old 12-02-2007 | 07:31 PM
Tbi-MAX's Avatar
maybe you guys can help me... how do i get my new open element to tighten up with the screw in the middle? as we all know the TBI, has a funny angle stud for the cleaner... the stud that came with my element is straight... i need something that will bend but is off centered and tall enough to fit my 14x4 cleaner...
where can i find a bigger bent stud? anyone with this problem?
Old 12-02-2007 | 08:20 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
I ended up making one. Length of steel rod (1/4" IIRC, some are 5/16"), and a die to thread it. Vice and hammer to bend it. Adjusted the bend angles to adjust the offset as it was being fit up.
RBob.
Old 12-03-2007 | 03:36 AM
Tbi-MAX's Avatar
RBob.
yea i figure i would have to bend the snot out of this straight peice, i just didnt know if it would break.. ill fab something up tomorrow, and let yall know how it went.. thanks
Old 12-03-2007 | 01:21 PM
oldred95's Avatar
You still have yet to learn the art of persuation. Take rod and grasp with both hands and bend. If it doesn't fit, make it fit. And if its too short, go get some coarse thread 1/4 inch all thread and make another one that does fit.
Old 12-03-2007 | 03:28 PM
Ronny's Avatar
When I bought my 7.4L TBI I believe it came with the rod to attach the AC to it? It appears as a .25 inch rod to what ever lenght you need. Just need appropriate thread at each end with correct offset
Old 12-03-2007 | 03:39 PM
Tbi-MAX's Avatar
only pic i got so far, but i bent it with 2 vice grips like Rbob said... its a 14x4 WIX filter... runs great with the 454tb.. i need to get a slightly smaller wingnut but other than that, it works great... but i may bend another rod to use this wignut...
Old 12-03-2007 | 07:15 PM
Tbi-MAX's Avatar
better pic.. to show the size of this thing.... you cant see the TBI period! just the heated riser...
another angle...
cant wait to get it tunned in for the BBC tb and injectors... lots of changes has been made.. now my intake matches the exhaust... muhaha
thanks guys...
hey how much CFM do you guys think this thing will actually flow? i need to get a pic of it with the lid off, then you guys can get a better pic of what im talking about.. but its also a drop filter.. so its huge.
1992 Trans Am
05-10-2023 08:19 PM
Fast355
12-02-2016 07:33 PM
mdtoren
08-16-2015 06:45 PM
92purpz28
08-11-2015 03:30 PM
