Stupid Question on aftermarket gadgets for TBI
I was recently surfing summit racing for fun and saw these wierd aluminum pieces they were calling tornado adapters that you put in the path of the air intake that supposedly make the air into a vortex going into the throttle body. I've heard half n half on reviews for those and thought I'd ask the experts on their opinions of them. I'm not sure I buy into the theory of them but hey sounds neat lol.
Any comments welcome![Smilie](https://www.thirdgen.org/forums/images/smilies/smile.gif)
Kaycee
Kaycee
1 Post
Car: 1991 RS, 84 El Camino conquista RIP
Engine: 5.0 (for now)
Transmission: 4L60
Axle/Gears: 2.xx torsen limited slip & 3.42 ope
Re: Stupid Question on aftermarket gadgets for TBI
not worth the price. The problem lyes in the air cleaner itself. that's not going to help much.
![my 2 cents](https://www.thirdgen.org/forums/images/smilies/twocents.gif)
I guess a pair of K&N filters would be alot better hehe.. What kind of problems are you referring to about the air cleaner assembly ?
Kaycee
Kaycee
1 Post
Transmission: 4L60
the stock drop air cleaner assembly is very restrictive. it's not letting your engine breath in very well.
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 91' Camaro
Engine: 383 ci
Axle/Gears: 9 bolt / 3:70
I am not doubtin they suck, but is there any proof they work or don't work? I have one in my 94' 3/4 ton Chevy, I just left it in there since it was there and I figured it can't hurt, but maybe it does...? If there is proof they hurt mpg or power, I'll pull it out and toss it...
Jason
Jason
Car: 89 RS
Engine: lo3
Transmission: 700R4 w/ B&M shift improver
Axle/Gears: 3.27 9-bolt posi
you're swirl port heads tumble the air over itself enough, you dont need any more obstructions in there.
1 Post
Car: 1987 Monte Carlo SS
Engine: 400 SBC
Transmission: 200-4R
Axle/Gears: 4.10
Yes when I was in tech school they proved on a dyno that the tornados decreased both power and economy. The results were published in one of the automotive magazines, unfortunately I can't remember which. It was in a green Ford F-150 4-door. Tornado was trying to work out a sponsorship deal with Hot Rod U at UTI, they declined after their findings.
1 Post
Transmission: 4L60
i can see the idea of swirling the air as a good thing but they slow the air and the ones that go into air base on our cars just cause problems
Car: 91' Camaro
Engine: 383 ci
I don't see a restriction with this thing, the stainless is so thin, I can't see it being restrictive. I may be totally wrong, but.....
I pulled it out and will drive without it for a month or so and see if the mileage changes any. I am betting I see no differance, the truck is a gutless turd anyways and gets pathetic gas mileage.. We shall see.
Jason
Jason
92camaroJoe
08-13-2015 06:07 AM
