68lbshr Injector#'S ???
Just wondering if anyone know's what the Gm part# for the cop car 68lbs injectors is?? Cant seem to find any definate answers. Any help would be great!! Thanks
Re: 68lbshr Injector#'S ???
but I can tell you, from what Ive noticed... its about a cazillion part numbers for TBI injectors... some discontinued, some after market... its just a whole bunch of damn numbers... for the same # injector...
Car: 1993 Caprice LTZ
Engine: 350 TBI
Transmission: 4L60 (700R4)
You can find them on Ebay too...they are all over...call up a parts locater service at a salvage yard...they can be gotten and you don't have to pay the dealer's BRAND New Price either.
Or you can email Dal too...he is THE MAN!!!
Here is Dal:
http://www.9c1.com/parts/whoisdal.htm
I just talked with Dal two days ago and he has now retired from Van Devere Olds. He has been working for another company out of TX. He is taking care of some personal things at home now and emails are easier to reply to then phone calls. If you would like to contact Dal please use this email.
lockitup@bright.net
He is very very busy as he receives calls from all over the place all day long...just be patient...he will get back to you. He is very dependable and he actually cares if you get what you want. He is the best and if you search for him online...you will find that he has a dedicated legion of followers. I am a certified member of the Dal fan club.
Good luck.
JB
Here is Dal:
lockitup@bright.net
Good luck.
JB
1 Post
Car: 1991 caprice / 96 caprice
Engine: 4?? bbc / lt-1
Transmission: 700r4 / 4l60e
Axle/Gears: 4.10/ 3.73
Ok now you guys got me?? I thought that the 305pu had 55lbhr injectors and that the 350's had 61lbs??? Is this not true??? I had the 305 injectors on my 350 for a very short period of time because they would not flow enough even at 20psi.
Car: 1983 G20 Chevy
Transmission: 4L60
The 305 (and B Vin HO 4.3) injectors are 55 lb/hr. 350 truck injectors are 61 lb/hr.
Car: check
Engine: check
Transmission: check
http://www.diy-efi.org/gmecm/compone...injectors.html
save this info for later. hth
As for the cop-car injectors, I do have some infomation. However, the reason I have not posted it is due to the flow rate. My understanding is that the early injectors are 65 #/hr, while the later ones (still marked in YEL/BRN) are 68 #/hr. For some reason I'm not sure if that is true or not. Anyway, here are the number's I have for the cop-car injectors:
350-L05/9C1 yellow/brown 65# 17084327,17112412
('89-'91)
350-L05/9C1 yellow/brown 68# 17100372,17100373
('92-'93)
RBob.
Hey thanks Rbob once again for that great info. Thats a relief, now I know that my bpw settings are still correct!! Thanks again you guys ROCK!!!!
