WinALDL 1.04a released
Car: 1984 Corvette
Engine: Turbo 350
Transmission: 4L80E with TCI T-Com
http://www.winaldl.webhop.net
* Added support for 1227170.
* New "Are you sure?" dialog when terminating the program.
* Buggfix 1227808 uses a new IAT calculation.
* Buggfix Odd behavior on the [Esc] and [Enter] keys.
Jonas Bylund
Sweeet
This program is just awesome! I can't thank you enough for all the work you're putting into it! It has made tuning my TBI sooooooo much easier ...... and do I dare to say, actually fun
Thomas.
1992 RS Camaro - Red
305-TBI/5 Speed Manual- 3.08 geared rear
1.6 Roller Rockers / Open Air K&N Filter / TBI Spacer / ADS Super Chip & custom burned Off-Road Only chip /
Headers - 3" Cat'Back - Flow Master - Adjustable Coni shocks & struts / 16" factory wheels
Thomas.
Car: 1984 Corvette
Engine: Turbo 350
I just released ver 1.05a.
Added support for 1227165 (1985-1986 TPI, 160 baud only).
Car: 91 Red Sled
wow, this is getting good
Jonas, any word on the timing display information? I don't know if you got my e-mail or not. Ken figured a way to change the data stream to display the ecm timing instead of battery voltage. The only problem was that it was a 16 bit value instead of the 8 bit. He even figured out the conversion and what needed to be changed in the eprom. Please get back to me about this through e-mail or the board. Thanks
Car: 1984 Corvette
Engine: Turbo 350
I can make a custom 7747 selection (might even autodetect).
It is probably better to use the PROMID. That is two bytes, and I already combine them to an interger. In the new version that variable will be in the sensor log, so scaling can be done in Excel too.
Car: 1984 Corvette
Engine: Turbo 350
Originally posted by Tas
how do I get this to work with windows2000?
Originally posted by JoBy
Did you run the instocx.bat?
"D:\winaldl>echo off
Windows 95 / 98 / ME detected
Installing msflxgrd.ocx
'D:\WINNT\system\regsvr32.exe' is not recognized as an internal or external comm and,
operable program or batch file
Press any key to continue . . ."
Then if I push a key, the Dos window disapears
Car: 1984 Corvette
Engine: Turbo 350
Ok, then the OCX file did not install. Perhaps your windows 2000 was installed in a non-standard way.
win2000 installed on the D-drive and win 98 on the C-drive. The instocx.bat detects the installation on the c-drive, and tries to install it accordingly, even whenn you boot win 2000.
I think that I have a solution. Download this instocx.bat. Replace the one from the zip.file and try it again.
http://w1.601.telia.com/~u60113744/s...dl/instocx.bat
If it works I will use that in the next release.
ya I run windows 98 on my C and windows 2000 on my D. I do all my computers like this. thanks Hopefully I'll test the program out soon when I make a cable.
edit: I ran the new thing you sent and it works yay
Great software Joby! It really helps on my car. My question to you is, My girlfriend owns a 1991 383 Speed Density TPI Trans Am. Do you have any plans for adding support for these cars in the future? I saw that you added 85-86 TPI, and saw a glimmer of hope. Thanks again for the great software.
Clint
Clint
Car: 91 Red Sled
Clint
Clint
Car: 1984 Corvette
Engine: Turbo 350
Clint
Clint
Jonas, do you know if an aldl cord for diacom will work with your winaldl program? Someone may have asked this before so forgive me for asking again. One last question. I have an old 486 nec laptop that only has windows 3.1, is this inadaquate to run your program on?
Steve
Steve
Car: 1984 Corvette
Engine: Turbo 350
I think that the Diacom cable connects to the printer port, and then it will not work.
You need to install at least Win95 to run WinALDL
I built the cable last night.. I checked the voltage coming out of my laptop for the transistor and it only puts out about 5 volts so I changed it and will hook up I beliveve to the h pin on the aldl to get my 12 volts.. question I have is don't you have to jump a 10k resistor from a to b on the aldl to have it send data on pin e??? I haven't been able to try it as I just picked up my rebuilt engine.. can't wait to put it in! it's about -7 celcius here right now so I might have to wait a while..
Car: 1984 Corvette
Engine: Turbo 350
Yes, on some ECM's you need a resistor between the A and B terminals on the ALDL connector.
I also updated the scematics in my web-page:
http://winaldl.webhop.net
/ Jonas
/ Jonas
Originally posted by steve8586iroc
Wouldn't be about as easy to take a volt meter and find out that way? A votl/ohm would work just fine. Just thought I'd through that out there for you.
Steve
Steve
Car: 1984 Corvette
Engine: Turbo 350
On my 84 Corvette pin H is not even connected.
You will have 12 V on pin G most of the time ( Fuel pump )
Car: 86 IROC
I see that 1988 F-body L03s are not on the list. Will you be adding them anytime soon?
Thanks for your effort on the program. You are certainly making our lives easier
Car: 1984 Corvette
Engine: Turbo 350
If you help me find the 160 baud data defenition then I can probably add it. I need something that describes what each bytes in the data means.
IROCZDAVE (88-L98)
09-22-2015 02:22 PM
