Smog Pumps and Open Air
Just for Curiosity, anyone who knows, i removed my smog pump, plugged the lines in the Exst. Manifolds, and added a K & N Open air filter and removed spacer ring from TBI. How much HP do you think I gained from this? and what is the stock factory HP rating for a 92 305 w/ tbi RS
Just take off the belt, remove the pulley and unbolt the pump off the front of the engine, you can re route the belt so you dont have to change it, remove the air lines and put in the plugs (just find plugs that are the same size as the air line fitting at a hardware store)
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
<font face="Verdana, Arial" size="2">Originally posted by Beat Fords?:
Can you explain how you removed the smog pump.I want to get that crap out of there but I am hesitant to try without getting alot of info since im a novice mechanic and this is my daily driver.</font>
<font face="Verdana, Arial" size="2">Originally posted by Camaro3051992:
remove the air lines and put in the plugs (just find plugs that are the same size as the air line fitting at a hardware store)</font>
1992 Camaro RS LO3 auto
180º thermostat, 14×3 K&N, Ultimate TBI Mods, !Cat, !Smog pump Flowmaster 80 series, and some audio stuff.
you gained maybe 1hp from teh smog pump if you are lucky, but you lost about 10lbs!!!!!
the air cleaner prolly gave you a nice 5-7hp across the power band.
later
tim
91 Camaro RS-LO3,Auto
New Times Coming Soon!
Check Out The East Coast F-Body Nationals Home Page
www.geocities.com/njspeeder
My MAFB.ORG Home Page
www.mycar.net/mafb/registry/detail.cfm?id=299
DSI Racing Home Page
www.geocities.com/foff667
later
tim
Car: 92 Camaro RS
Engine: 350 Crate Motor
Transmission: Tremec TKO
Axle/Gears: 10 Bolt 3.73
Yeah, recently read an article that said the smog pump is only worth 1 HP on a stock or mildly modified motor, but it is heavy.
-Rich-
-Rich-
That tech article doesn't have my engine in it. So I doesn't me too much... My smog pump is on the lower left if Im facing it...
92 Camaro 305 TBI Automatic
https://www.thirdgen.org/rides/index...ew&rideid=6100
I dont recall the size of plugs, but the main reason i wanted to take off the smog pump was to get rid of the air lines to have access to all of the spark plugs and wires and crap, I even have room to install headers in there if i want.
by the way, do you have to remove the AC stuff to get a header on the passesger side
Car: 91 Red Sled
No need to remove the A/c for header installs. Might have to bend the tranny fluid lines a little to get the headers in place and make sure the lines don't rest on the headers!!!
Tell you what "Beat Fords", the Smog pump comes right off-2 bolts, and all the other AIR crap comes off easily too. You might as well slap on some headers since your turning the car into a non-smog legal ride anyway. But if not, just cut the steel AIR line from the CAT and weld it shut. Im from AZ so I dont have any smog regs where Im at. I took all that crap off too. Had to buy a longer belt to reroute it the right way, cant remember the # though(sorry). Made lots of room in the Bay though. As for the headers, I ended up unbolting the motor from the mounts and lifting it up about an inch or so. PITA. Good luck brother!!
92 Teal RS
305 TBI
Thermomaster Chip-160Deg Stat
K&N
Custom Throttle Return Bracket
Heddman 1-5/8 Headers
Hooker 3" (Y-Pipe Back)Dual 2-1/2 Outs
Intrax 2" Springs, Spohn Panhard,
17x8 Sabers
[This message has been edited by big green monster (edited December 04, 2001).]
92 Teal RS
305 TBI
K&N
17x8 Sabers
1/4" tapered pipe thread plugs are what you need. I have a set of 8 for anyone who wants them, I'll take two dollars for shipping, and send them. I have headers now w/o the smog stuff on them.
1991 Firebird Bandit II Edition
305 LO3 A4 with mods:
True Dual 2 1/2" Exhaust;
Dynomax Shorty Headers
Hedman X-Pipe
2 Dynomax Free-Flowing Cats
2 Dynomax Glass Packed Mufflers
160* thermostat
Jet Stage II Powerchip
no smog pump/pulley/AIR tubes
A/C delete (need delete pulley)
K&N Open Element cleaner
Ultimate TBI Mods (port/polish, AFPR)
1" TBI Spacer .25" Injector Spacer
Homemade Subframe Connectors
GM Wonderbar
36mm front, 24mm rear sway bars with Poly bushings/endlinks
Waiting to install;
95 Z28 LT1 Camshaft
1.6:1 RR
Bryco double roller timing set
LT4 valve springs
+ one large lead pedal foot . See my project rocket turtle @
http://oursportscars.homestead.com/firebird.html
Member of Tidewater Trans Am Club
www.ttac.net
Hedman X-Pipe
160* thermostat
GM Wonderbar
Waiting to install;
95 Z28 LT1 Camshaft
1.6:1 RR
LT4 valve springs
www.ttac.net
mdtoren
08-16-2015 05:45 PM
