350 Won't Start-Only Backfires
Car: '90 Camaro RS, '94 Miata, '95 F-250
Engine: 5.7 TBI V8, 1.8 PFI L4, 7.5 PFI V8
Transmission: 4L60-OD, 5spd Std, 5Spd Std
Axle/Gears: 2.73 Posi, 4.10 LSD, 3.55 Posi
I've got a 350 sitting in my Camaro, it was already swapped when I bought it, and run good until I blew the motor up, I've got this one in and it won't start, just turns over and and if I hold the throttle open it'll backfire through the TBI. I'm sure I have the timing right, cause I set it with the valve covers off to watch the rockers and also by the timing mark on the balancer.
I've set and reset the valves, but that still maybe the problem...
Car: 91 Camaro RS
Engine: Small Block
Transmission: TH350 w/ 3000 stall convertor
Axle/Gears: 3.73 w/ powertrax locker
Re: 350 Won't Start-Only Backfires
Eric-86sc
08-24-2015 09:01 PM
