Stock TB power?!?
Stock TB power?!?
Ok, How much power/torque could I reasonably make with a TBI 350? The tb unit is modified with 350 injectors from the chev dealer, but otherwise stock. the engine is 9:1 compression, with a decent cam. I want to stick with the stock tb unit, unless I can't get decent power. (without nitrous, for now)
I think www.sdpc2000.com said 280HP with the old GM 350 H.O. 300hp crate engine, edelbrock TBI intake and stock size TBI.
-Tas
'89 Formula WS-6
305, TBI, 700R4, P.A.W. 14x3 open element with K&N, Milodon 160* thermo, functional Formula hood, cross-flow Flowmaster, '99z28 rear pipes and tips, Hooker 1-5/8" 50 state legal headers, Dynomax 3" I pipe (PN 44063 and 43248)
Super GRK_Taz World
F-Body Dual Exaust
EFI & Intake Options
AOL IM: superGRtaz
Got Beach?
-Tas
'89 Formula WS-6
Super GRK_Taz World
F-Body Dual Exaust
AOL IM: superGRtaz
Got Beach?
Car: 92 Camaro RS
Engine: 350 Crate Motor
Transmission: Tremec TKO
Axle/Gears: 10 Bolt 3.73
Most I have spoken to say about 300 HP is the reasonable limit for GM TBI.I bought a 300HP
crate motor and it runs fine.GM no longer sells a 300HP,and the Vortec 330HP motor requires the new Vortec TBI manifold and EGR adapter connected to the exhaust if it has to pass emissions testing.
1992 RS,5 Speed,T-Tops,Eibach Springs(cut), KYB's, Lakewood Trailing Arms and Adjustable Panhard Bar,Posi Disc Rear,3.73 Gears,Summit Rearend Support Cover,
Del-A-Lum Bushings,300 HP Crate Motor,Crane Comp-U-Cam,Edelbrock TBI Intake, Turbo City Ported Throttle Body and Adjustable Fuel Pressure Regulator,Open Element
Air Cleaner, Ground Control Strut Tower Brace and Caster/Camber Adjusters,SLP 1-5/8" Headers,Flowmaster 3" American Thunder Exhaust,3" Cat,Centerforce Dual
Friction Clutch,Hayes Billet Flywheel,B&M Power Steering Cooler,Big Thumpin' Stereo.
